Transmit mic data over BLE
I'm trying to use Arduino nano 33 BLE sense to transmit mic data over BLE. For some reason after starting PDM, the code never comes back from the function BLE.begin(). This doesn't happen when removing the PDM part. Why does this happen?
#include <PDM.h>
#include <ArduinoBLE.h>
#define BUFF_SZ 100
short sampleBuffer[BUFF_SZ];
const char* deviceServiceUuid = "19b10000-e8f2-537e-4f6d-d104768a1215";
const char* deviceServiceCharacteristicUuid = "19b10001-e8fd-537e-4f6c-d104768a1215";
volatile int samplesRead = 0;
BLEService gestureService(deviceServiceUuid);
BLECharacteristic gestureCharacteristic(deviceServiceCharacteristicUuid, BLERead | BLEWrite | BLENotify, BUFF_SZ);
  while (!Serial);
  PDM.onReceive(onPDMdata);
    if (!PDM.begin(1, 16000)) {
    Serial.println("Failed to start PDM!");
    while (1);
  Serial.println("Mic started");
  if (!BLE.begin()) {
    Serial.println("Starting Bluetooth Low Energy module failed!");
    while (1);
  Serial.println("BLE LED Peripheral");
  BLE.setLocalName("Arduino Nano 33 BLE (Peripheral)");
  BLE.setAdvertisedService(gestureService);
  gestureService.addCharacteristic(gestureCharacteristic);
  BLE.addService(gestureService);
  BLE.advertise();
BLE is designed and intended for very infrequent transmissions of very small amounts of data.
It does not make sense, and is probably impossible to use it for transmitting 16000 microphone sound samples every second.
Edit: I checked, and if you use the very latest BLE libraries on both ends, with very carefully chosen parameters, it is just barely possible to transmit data at that rate of 256 kbps. See A Practical Guide to BLE Throughput | Interrupt
But I can't even get the BLE to start together with PDM. I would downsample it to reduce the datarate but I'm not even that far yet.
Forget the BLE for the moment, and check whether the PDM microphone works.
For example, print out the data.
Where is the rest of the code? This can't possibly work if you haven't defined a function to do something with the data:
Here is the entirety of the code. I didn't include it because the thing get's stuck before it even gets to that part of the code
#include <PDM.h>
#define BUFF_SZ 100
  while (!Serial);
  if (!BLE.begin()) {
    while (1);
  BLE.advertise();
  //PDM.onReceive(onPDMdata);
    while (1);
 /* BLEDevice central = BLE.central();
  if (central) {
        Serial.print("Connected to central: ");
    // print the central's MAC address:
    Serial.println(central.address());
    while (central.connected()) {
      if (samplesRead) {
        gestureCharacteristic.writeValue(sampleBuffer,samplesRead);
        samplesRead = 0;
void onPDMdata() {
  // query the number of bytes available
  int bytesAvailable = PDM.available();
  // read into the sample buffer
  PDM.read(sampleBuffer, bytesAvailable);
  // 16-bit, 2 bytes per sample
  samplesRead = bytesAvailable;
Try what I suggested: remove the BLE stuff and just print out the microphone data.
BTW are you SURE that the samples are bytes? They certainly aren't on my NRF52840 setup. You may be wiping out memory by writing past buffer boundaries.
Here is the code that I use to write 16 bit PDM microphone data to a file on QSPI flash, developed for the Adafruit Clue NRF52840, running at 48 MHz.
It turns out that flash memory is too slow for 256 sample (512 byte) audio buffers, and audio samples were dropped at regular intervals.
The sample buffer size had to be increased to 1024 to overcome that limitation, so, I am completely confident that BLE cannot handle the task you have in mind.
//working 4/2024
// upped gain to 42 (default was 20, too quiet)
// large sample buffer is required to overcome slow write speed to flash
  This example reads audio data from the on-board PDM microphone
  and saves to a QSPI flash file audio.dat
  // 2Mb flash = 2097152 bytes, 4096 512 byte blocks
#include <Adafruit_Arcada.h>
Adafruit_Arcada arcada;
#include <PDM.h>
// buffer to read samples into, each sample is 16-bits
// setting a larger buffer avoids dropping audio samples
// write to flash are slow!
int16_t sampleBuffer[1024];
// number of samples read
volatile int samplesRead;
File file;
  while (!Serial) yield();
  // configure the data receive callback
  if (!arcada.arcadaBegin()) {
    while (1);
  //Arcada_FilesystemType
  arcada.filesysBegin(ARCADA_FILESYS_QSPI);
  file = arcada.open("/audio.dat", O_CREAT | O_WRITE);
  if (!file) {
    Serial.println("\r output file open failure");
    while (1) yield();
  PDM.setBufferSize(2048);  //bytes!
  // initialize PDM with:
  // - one channel (mono mode)
  // - a 16 kHz sample rate
    while (1) yield();
  // optionally set the gain, defaults to 20
  PDM.setGain(42);
  Serial.println("recording");
int nframes = 250;
  // wait for samples to be read
  if (samplesRead) {
    file.write((char *)sampleBuffer, 2048);
    //    Serial.println(nframes);
    nframes--;
    if (nframes == 0) {
      file.close();
      Serial.println("stopped");
      arcada.filesysListFiles();
      Serial.flush();
      while (1) yield();
    samplesRead = 0;
void onPDMdata() { //callback
  samplesRead = bytesAvailable / 2;
