I am new to circuits so I appreciate any help. I have a 315MHZ transmitter/receiver pair but they are not working correctly. I have a Teensy 2.0 reading the value of analog sticks and then sending that value through the transmitter to and Arduino Nano 3.0. My problem is that the signal being outputted by the transmitter is a lot stronger(higher) than the one being received by the receiver.(I attached my oscilloscope image to help you understand the problem, CH1 is my transmitter and CH2 is the receiver). please give me any ideas you have, at this point ill try anything.
And the options could very well be
(a) if reliable operation is required then use antennas.
(b) if reliable operation is not required then don't use antennas.
One wouldn't normally think that antennas are necessary for a 6" range, but you are talking about very inexpensive (cheap) devices.
I added the Antennas yet the problem has not gone away.
KE7GKP: Yes it was from the correct data output pin on the receiver, I double checked after your suggestion. I agree that the signal is getting there but it is very low but why?
