Trick for 16-rows display using Parola :)
marco_c:
You have a more dynamic message. No difference.
Could you please suggest a method of passing a dynamic message into a char. I mean how can I declare my char timeStamp into a static one so that I can utilize it as a string or word which can be printed out.
P.displayText(timeStamp, ....
won't work because I tried. Is there any other way like changing the char timeStamp[] into a word or string?
Time stamp should already be an array of characters or sprintf() and print() will not work.
marco_c:
Atlast I managed to scroll the time. Thanks for the guidance.
But after every scroll_left of time, the date flashes and again scrolling of time continues.
#include <Wire.h>
#include <MD_DS1307.h>
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include <RTClib.h>
#define MAX_DEVICES 4
#define CLK_PIN   13
#define DATA_PIN  11
#define CS_PIN    10
#define PAUSE_TIME    3000
#define SCROLL_SPEED  30
RTC_DS1307 rtc;
//MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
void setup ()
  Wire.begin();
  Serial.begin(57600);
  P.begin();
 if(! rtc.begin())
    Serial.println("Couldn't find RTC");
    while (1);
 if(! rtc.isrunning())
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
     rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop ()
DateTime now = rtc.now();
char timeStamp[15];
char dateStamp[15];
sprintf(timeStamp, "%d:%d", now.hour() ,now.minute());
Serial.println(timeStamp);
sprintf(dateStamp, "%d/%d",  now.day(),now.month());
Serial.println(dateStamp);
 for (uint8_t i=0; i<ARRAY_SIZE(timeStamp); i++)
       P.displayText(timeStamp, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCROLL_LEFT);
      while (!P.displayAnimate())
P.print(dateStamp);
The looping continues with flashing date after every scroll_left.
I am planning to scroll the date after the timeloop finishes.
vijithcv:
Atlast this is what I came up with. Please let me know if I can simplify the program. But anyhow it works. Hope new year will become 01/01/2018 :wink:
#include <Wire.h>
#include <SPI.h>
#include <RTClib.h>
#define CLK_PIN   13
#define DATA_PIN  11
#define CS_PIN    10
RTC_DS1307 rtc;
void setup ()
  Wire.begin();
  P.begin();
 if(! rtc.begin())
    while (1);
void loop ()
char timeStamp[15];
char dateStamp[15];
sprintf(timeStamp, "%02d:%02d", now.hour() ,now.minute());
sprintf(dateStamp, "%02d/%02d",  now.day(),now.month());
P.displayText(timeStamp, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_MESH);
P.displayAnimate();
 for (uint8_t q=0; q<ARRAY_SIZE(timeStamp); q++)
 int dow = now.dayOfTheWeek();
 char *d   ;
  switch(dow)
     case 1:
     Serial.println("MON");
     d = "MON";
     case 2:
     Serial.println("TUE");
    d = "TUE";
     case 3:
     Serial.println("WED");
  d = "WED";
     case 4:
     Serial.println("THU");
    d = "THU";
     case 5:
     Serial.println("FRI");
   d = "FRI";
     case 6:
   Serial.println("SAT");
   d = "SAT";
     case 0:
     Serial.println("SUN");
   d = "SUN";
P.displayText(d, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_BLINDS);
P.displayAnimate();
for (uint8_t j=0; j<ARRAY_SIZE(dateStamp); j++)
 P.displayText(dateStamp, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCROLL_LEFT);
for (uint8_t r=0; r<ARRAY_SIZE(dateStamp); r++)
 int moy = now.month();
 char *e   ;
  switch(moy)
     case 1:
     Serial.println("JAN");
    e = "JAN";
     case 2:
     Serial.println("FEB");
   e = "FEB";
     case 3:
     Serial.println("MAR");
  e = "MAR";
     case 4:
     Serial.println("APR");
    e = "APR";
     case 5:
     Serial.println("MAY");
   e = "MAY";
     case 6:
   Serial.println("JUN");
   e = "JUN";
     case 7:
     Serial.println("JUL");
   e = "JUL";
case 8:
     Serial.println("AUG");
   e = "AUG";
case 9:
     Serial.println("SEP");
   e = "SEP";
case 10:
     Serial.println("OCT");
   e = "OCT";
case 11:
     Serial.println("NOV");
   e = "NOV";
case 12:
     Serial.println("DEC");
   e = "DEC";
P.displayText(e, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCAN_HORIZ);
P.displayAnimate();
for (uint8_t k=0; k<ARRAY_SIZE(dateStamp); k++)
  int iVarToCast = now.year();
  char buffer[4];
  dtostrf(iVarToCast, 4, 0, buffer);
P.displayText(buffer, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCROLL_LEFT);
Serial.println(buffer);
vijithcv:
Everything works except two issues.
  1. The Week and Month name is clipped if I use the scroll function. Eg: It shows only Januar and while it scrolls it doesn't display the remaining.
  2. The seconds doesn't increment while I enable the Parola scroll or any other animation. Its like the current second is saved in the char array and its displaying that value at that instant only.
I added a LM35 Sensor and I face the same issue wherein the temperature is not displayed real time. If there is any increase in temperature its displayed in the next animation sequence. Its also like frozen.
I think when the value is put into a char array and while using Parola library it shows the value as a word and any change in the value is shown in the next cycle of animation.
I hope i made my problem little bit clear.
Anyway it keeps the time and temperature day and date properly. Only minus I am not getting a live display.
nyc work sir....i'm also trying lyk this...
Total 32 (8x8)matrices taken as 2 zones.....
0-15 Bottom zone,
16-31 TopZone.
Here my problem is the two zones are not synchronized eachother...When i increse the scrolling speed,the bottom zone move forward than upperzone...they not synchronized..
please help me...
give me suggetions...
thanq,
Sankar.
Hello, I am getting error that 'CENTER' is not declared in the scope. Please help me. My matrix display is 16 (height) x 64 (length). Please help me with coding.
Seriously?
enum textPosition_t
  PA_LEFT,    ///< The leftmost column for the first character will be on the left side of the display
  PA_CENTER,  ///< The text will be placed with equal number of blank display columns either side
  PA_RIGHT    ///< The rightmost column of the last character will be on the right side of the display
Please read the documentation supplied with the library and/or the header files. We will all find it less frustrating.
hi .. can help post example coding? i have 16x32 matrix.
Hi! i was testing the code from the beginning of this thread and by the way i am using 16 modules of LED matrix divided in 2 zones. my issue is that the first module of the project is dim can you help me fix this one?
