Hi i am trying to make a handphone call via arduino mega 1280. With the command below i am able to make the phone show "Callling 96631890" then "connecting 96631890" but it will not reach 96631890 nor ring . I checked the call list but 96631890 don't appear . Anyone know what could i add to make the call sucessful ?
Wow, the AT command set, really testing my memory, so i might be wrong. Do you have touch tone service? I think ATD dials with pulse dial, while "ATDT" dfoes a touch tone dial...
skyjumper:
I tried ATDT and ATD, both can't dial the cellphone number but i am able to dial my Landline House phone number sucessfully with both ATDT and ATD!!!
werid anyone know how to dial the Cellphone number successfully ?
I'd recheck the cell phone number and make sure you are using all the required numbers.
Well i believe i am using the correct number for dialling, Because i saved the number I.E apple as 96631890 , as i execute the ATD command, the phone show "Calling Apple" "Connecting Apple" but cut off immediately after that. If i change the number to my house phone number (Landline), it works !! but i need to work with another cellphone!!!
dxw00d:
Presumably you can dial the number manually ok?
Yes i am able to dial manually. Anyway i also found one thing werid is that although i can dial my house number sucessfully but when i pick it up, i can't hear anything nor the other user can hear me talking.
It is a few years since I did this, but I recall that the mobile I was using used an extension of the basic AT command set in order to set up and tear down calls. Have you tried connecting your handset to a PC and just controlling it manually using hyperterminal or similar? Probably easier than trying to figure out how it works using a sketch.
