Trouble connecting MQ3 alcohol gas sensor to LCD screen
Our group is working on building the circuit involving a MQ3 alcohol gas sensor in order to measure an individuals BAC and have the reading show up on an LCD screen. We are also using a buzzer to alert when the user should stop blowing on the sensor. We followed the schematic correctly, but our code will not get passed the verifying stage. We repeatedly are getting the "Exit Status" message. Can anyone help me debug our program? Thank you
// Libraries
#include <Wire.h>
#include <LiquidCrystal.h>
// Warmup
int TIME_UNTIL_WARMUP = 20;
unsigned long time;
// Measurement
int TIME_UNTIL_MEASURE = 5;
unsigned long measurement_start;
// Sensor readings
int analogPin = A0;
int val = 0;
// Buzzer
const int buzzerPin = 7;
// Modes
bool measurement_mode;
bool measurement_done;
// LCD
LiquidCrystal lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
// Serial
// Init LCD
lcd.init();
lcd.backlight();
// Warmup
if(time<=TIME_UNTIL_WARMUP)
int progress_time = map(time, 0, TIME_UNTIL_WARMUP, 0, 100);
printWarming(progress_time);
if (measurement_mode == false && !measurement_done) {
// Instruction
printPress();
if (measurement_mode && !measurement_done) {
// Instruction
printMeasure();
// Sound
tone(buzzerPin, 1000);
// Read alcohol level
val = readAlcohol();
if (measurement_mode && !measurement_done && ((time - measurement_start)> TIME_UNTIL_MEASURE)){
noTone(buzzerPin);
measurement_mode = false;
measurement_done = true;
lcd.clear();
if(measurement_done) {
printAlcohol(val);
printAlcoholLevel(val);
void printWarming(int progress)
lcd.setCursor(0,0);
lcd.print("Warming up: ");
lcd.print(progress);
lcd.print("%");
void printPress()
lcd.setCursor(0,0);
lcd.print("Press to start ...");
void printMeasure()
lcd.setCursor(0,0);
lcd.print("Breathe until the ");
lcd.setCursor(0,1);
lcd.print("sound stops ...");
void printAlcohol(int value)
lcd.setCursor(0,0);
lcd.print("Sensor reading: ");
lcd.print(val);
void printAlcoholLevel(int value)
lcd.setCursor(0,2);
if(value<200)
lcd.print("You are sober.");
if (value>=200 && value<280)
lcd.print("You had a beer.");
if (value>=280 && value<350)
lcd.print("Two or more beers.");
if (value>=350 && value <450)
lcd.print("Too much ...");
if(value>450)
lcd.print("You are drunk!");
int readAlcohol()
// Number measurements
int nb_measurements = 5;
int measurements;
// Measure
for (int i = 0; i < nb_measurements; i++) {
measurements = measurements + analogRead(analogPin);
measurements = measurements/nb_measurements;
return measurements;
When are people going to post code correctly ?
Probably never I predict
Here is it formatted and posted correctly
// Libraries
#include <Wire.h>
// Warmup
unsigned long time;
// Measurement
// Sensor readings
int analogPin = A0;
int val = 0;
// Buzzer
// Modes
// LCD
LiquidCrystal lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
  // Serial
  // Init LCD
  lcd.init();
  lcd.backlight();
  // Warmup
  if (time <= TIME_UNTIL_WARMUP)
      // Instruction
      printPress();
      // Instruction
      printMeasure();
      // Sound
    if (measurement_mode && !measurement_done && ((time - measurement_start) > TIME_UNTIL_MEASURE))
      noTone(buzzerPin);
      lcd.clear();
    if (measurement_done)
      printAlcohol(val);
  lcd.setCursor(0, 0);
  lcd.print("%");
void printPress()
void printMeasure()
  lcd.setCursor(0, 1);
  lcd.print(val);
  lcd.setCursor(0, 2);
  if (value < 200)
  if (value >= 200 && value < 280)
  if (value >= 280 && value < 350)
  if (value >= 350 && value < 450)
  if (value > 450)
int readAlcohol()
  int measurements;
  // Measure
  measurements = measurements / nb_measurements;
Does the time variable ever change from its initial value of zero in this code ?
Where is this message coming from ?
