Hello.
I am trying to establish a connection to Internet using an ESP8266 and an Arduino Uno.
I am using the following connections for the circuit:
An the following code:
// Programa: Versao firmware modulo ESP8266 e
// mudanca de baud rate
// Autor : FILIPEFLOP
#include <SoftwareSerial.h>
//RX pino 2, TX pino 3
SoftwareSerial esp8266(2, 3);
#define DEBUG true
// Configure na linha abaixo a velocidade inicial do
// modulo ESP8266
esp8266.begin(115200);
sendData("AT+RST\r\n", 2000, DEBUG);
Serial.println("Versao de firmware");
delay(3000);
sendData("AT+GMR\r\n", 2000, DEBUG); // rst
// Configure na linha abaixo a velocidade desejada para a
// comunicacao do modulo ESP8266 (9600, 19200, 38400, etc)
sendData("AT+CIOBAUD=19200\r\n", 2000, DEBUG);
Serial.println("** Final **");
void loop() {}
String sendData(String command, const int timeout, boolean debug)
// Envio dos comandos AT para o modulo
String response = "";
esp8266.print(command);
long int time = millis();
while ( (time + timeout) > millis())
while (esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
response += c;
if (debug)
Serial.print(response);
return response;
However, when running the code all I get in the Monitor Serial is:
⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮w⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮w⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮Versao de firmware
⸮⸮⸮⸮⸮wo⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮o⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮w⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮** Final **
Does anybody have any idea on what may be going wrong?
Thanks in advance
