Trouble displaying webserver when connected to DSL router
I am using an Uno with an ethernet shield piggy backed. Have loaded the standard webserver sketch with the IP address 192.168.1.177 for the uno. If I connect the Uno to my laptop directly using an RJ45 cable and open a web browser on the laptop, type in the IP address, the webserver displays the expected output showing the 6 analog channels.
While this is connected I get the following repeated output via the serial monitor-
server is at 192.168.1.177
gateway is at 192.168.1.1
subnet mask is 255.255.255.0
dns server is at 192.168.1.1
client disconnected
new client
GET /favicon.ico HTTP/1.1
Host: 192.168.1.177
Connection: keep-alive
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
Accept: /
Referer: http://192.168.1.177/
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-US,en;q=0.8
If I now connect the Laptop to say DSL router port 1 and the Uno to DSL router port 2 and open a web browser typing in the 192.168.1.177 address again, I get site unreachable.
The serial output is
Im using -
192.168.1.177 for the Uno
192.168.1.1 for the gateway (DSL router- TP link TD-W8901G 4 port)
192.168.1.1 for the DNSserver
and subnet mask 255.255.255.0
Most forums and articles dont mention connection via a switch or router just "connect it and it will display"
Any help appreciated.
thanks
sketch below
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at "); Serial.println(Ethernet.localIP());
  Serial.print("gateway is at "); Serial.println(Ethernet.gatewayIP());
  Serial.print("subnet mask is "); Serial.println(Ethernet.subnetMask());
  Serial.print("dns server is at "); Serial.println(Ethernet.dnsServerIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
    Ethernet.maintain();
Try the DHCPAddressPrinter example sketch. What serial messages do you get with it?
Thanks SurferTim
With the Uno and the laptop connected to separate DSL router ports and serial connected to laptop, I uploaded DhcpAddressPrinter from IDE and it loaded successfully.
After some time serial monitor returned
"Failed to configure Ethernet using DHCP"
That is odd. Normally the DSL router has a DHCP server active. Does your laptop get an IP from the DSL router?
Yeah last one was 192.168.1.110
Ideally with the Uno being a webserver I want to set this myself (ie .177 or whatever)
If I ping (192.168.1.177) from laptop with this setup it responds with what seems a response from the router back but indicates destination host unreachable, I assume this means the laptop is talking to the router but the hop from the router to the Uno is not responding.
That would be a correct assumption, considering the Arduino can't get an IP via DHCP.
I'm going to try another router as the one I'm using is older and having to reset constantly with not retaining password. Im assuming the webserver sketch should be pretty straightforward if all devices are working properly.
Thanks for the help so far.
Tried a different router and immediate success. for some reason the TP link ports were not working correctly.
Thanks for the help
TP-Link products have caused problems with the ethernet shield for several users here. You are not alone.
I got similar behaviour with accton manufacturer, aka ( smc, 3-com, usr-robotics, fonera ) and not only home user products, with professional series too.
