Hi there,
I've been trying to get two TSL2561 LUX sensors (i2c) on my Arduino Mega with not much success. The first sensor is connected to SCL and SDA on the board itself and the second is connected to A4 and A5 via a CC3000 WiFi Shield. The connection to SCL/SDA works no problem but the latter does not.
The peculiar thing is that if I place the CC3000 on an Arduino Uno, both sensors work without issue. This makes me think its a hardware issue, but maybe there are differences between the two that I do not know of? I've checked the connections many, many times and it all looks fine. I've included the Fritzing diagram for the setup for completeness.
Code:
//Sensor Libraries
#include <DHT.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2561_U.h>
//LCD Screen Library
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
//WiFi Connection Libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
//MQTT Libraries
#include <PubSubClient.h>
#include <Time.h>
//Wi-Fi Shield Details
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed but DI
//Wi-Fi Credentials
#define WLAN_SSID "" // cannot be longer than 32 characters!
#define WLAN_PASS ""
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
Adafruit_CC3000_Client client;
// MQTT / Broker Information
#define MQTT_Broker "10.0.1.4"
IPAddress ip(10,0,1,2);
IPAddress server(10,0,1,4);
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
PubSubClient mqttclient("10.0.1.4", 1883, callback, client);
//Sensor Setup
//Light
//The final number, in this case 1, must be unique
//tslwin addr is grounded. tslroom addr is floating
Adafruit_TSL2561_Unified tslroom = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 1);
Adafruit_TSL2561_Unified tslwin = Adafruit_TSL2561_Unified(TSL2561_ADDR_LOW, 2);
//Temperature
#define DHTPIN A2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
//PIR Sensor
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
//Timer for motion detection
int timer = 0;
//LCD Display Setup
//String sendData(String command, const int timeout, boolean debug);
//Software SPI (slower updates, more flexible pin options):
// pin 9 - serial clock out (SCLK)
// pin 8 - Serial data out (DIN)
// pin 7 - Data/Command select (D/C)
// pin 6 - LCD chip select (CS)
// pin 4 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(9, 8, 7, 6, 4);
//Buffer definition
#define MAX_OUT_CHARS 16
char buffer[MAX_OUT_CHARS + 1];
void setup(void)
//Initialise Display
display.begin();
display.setContrast(50);
display.display();
delay(2000);
display.clearDisplay();
//BEGIN NETWORK CONNECTION
Serial.println(F("\nInitialising the CC3000 ..."));
if (!cc3000.begin())
Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
while(1);
/* Delete any old connection data on the module */
Serial.println(F("\nDeleting old connection profiles"));
if (!cc3000.deleteProfiles()) {
Serial.println(F("Failed!"));
while(1);
/* Attempt to connect to an access point */
Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100);
//END CONNECTION INFORMATION (Close connection below)
//Call configure sensors
dht.begin();
display.println("Initialising Sensors...");
Serial.println("Initialising Sensors...");
configureSensor();
//setSyncProvider(getNtpTime);
Serial.println("Time: ");
Serial.println(hour());
Serial.println(minute());
Serial.println(second());
//Connect to Broker
Serial.println("Attempting to connect to broker...");
mqttclient.connect(MQTT_Broker);
if (mqttclient.connect(MQTT_Broker)) {
Serial.println("Connected to broker!");
else {
Serial.println("Failed to connect to broker!");
void loop(void)
delay(2000);
val = digitalRead(inputPin); // read input value
//Sensor Setup
char buf[16];
float humidity = dht.readHumidity();
float temperature = dht.readTemperature(false); //false = C, true = F
//Light Sensor int to String, to char array
sensors_event_t eventroom;
tslroom.getEvent(&eventroom);
float lightroom = eventroom.light;
char* strLightRoom = dtostrf(lightroom, 5, 0, buf);
Serial.print(strLightRoom);
mqttclient.publish("lightroom", strLightRoom);
display.print("LUX R: ");
display.println(strLightRoom);
sensors_event_t eventwin;
tslwin.getEvent(&eventwin);
float lightwin = eventwin.light;
String strLightWin = dtostrf(lightwin, 5, 0, buf);
String payload = "{\"DeskSensor\":{\"Temperature C\":";
payload += strLightWin;
payload += ",\"timestamp \":";
payload += hourFormat12();
payload += "}}";
Serial.print(strLightWin);
mqttclient.publish("lightwin", (char*) payload.c_str());
display.print("LUX W: ");
display.println(strLightWin);
//Humidity Sensor int to String, to char array
char* strHumidity = dtostrf(humidity, 5, 1, buf);
Serial.println(strHumidity);
mqttclient.publish("hum", strHumidity);
display.print("Hum: ");
display.print(strHumidity);
display.println("%");
//Temperature Sensor int to String, to char array
char* strTemp = dtostrf(temperature, 5, 1, buf);
Serial.println(strTemp);
mqttclient.publish("temp", strTemp);
display.print("Temp: ");
display.print(strTemp);
display.println("C");
if (val == HIGH) { // check if the input is HIGH
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
timer = 0;
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
timer++;
sprintf(buffer,"Timer at: %d", timer);
Serial.print(buffer);
mqttclient.publish("motion", "Motion Detected");
display.println(buffer);
if (timer >= 15){
Serial.println("USER LEFT!");
display.println("USER LEFT!");
display.display();
void configureSensor(void)
tslroom.enableAutoRange(true);
tslroom.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);
tslwin.enableAutoRange(true);
tslwin.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);
Note:
- TSL2561 in the diagram is missing the INT pin, but this doesn't matter as it is not in use.
- Diagram shows Arduino Uno because the project was initially based on it and has been migrated to the Mega. The only differences that this make is that the SDA and SCL pins that originally connect through the CC3000 to the Arduino are left hanging and the connect is instead made to the SDA and SCL pins on the Mega itself.
Any assistance would be much appreciated!
Cheers!
