Trouble logging to a micro SD card
I am working on a way to log data from a pressure sensor onto a micro SD card but it is proving difficult. My problem is that after I run the sketch and open up the micro SD card the file is there but there is no data on the file.
I have been able to identify the micro SD card using the "Cardinfo" Arduino library. I have been able to log example data to it using the "Datalogger" Arduino library. And I have tried printing out the values that would be logged and the results are perfect proving that the sensor works. I am clueless as to what is going on and need help.
Thanks for your time.
I am using an Adafruit Micro SD card slot
Here is my code
#include <Wire.h>
#include <LPS.h>
#include <SPI.h>
#include <SD.h>
float altitude_difference = 0;
const int chipSelect = 10;
float TimeKeeper=0;
float alt_present = 0;
float  startingPressure=0;
float Velocity = 0;
float Altitude=0;
float Altitude1 = 0;
  int launch = 0;
  int trigger=0;
float Apogee=1;
float Maxvel = 0;
LPS ps;
  Wire.begin();
  if (!ps.init())
    Serial.println("Failed to autodetect pressure sensor!");
    while (1);
pinMode(10, OUTPUT);
SD.begin(chipSelect);
  ps.enableDefault();
   float pressure = ps.readPressureMillibars();
  float altitude = ps.pressureToAltitudeMeters(pressure);
 Altitude1 = altitude;
  File flight1 = SD.open("Fli.txt", FILE_WRITE);
 Altitude= altitude - Altitude1;
 float alt_past = altitude;
float Velocity_past = Velocity;
    delay(30);
  float alt_present = altitude;
float altitude_difference= alt_present - alt_past;
Velocity = altitude_difference+ 0.05 /0.094;
delay(30);
  if (flight1) {
    flight1.println(Altitude);
  if (launch <= 1) {
 if(Altitude>1.5) {  Serial.print("p: ");
 flight1.print(pressure);
  flight1.print(" mbar\ta: ");
  flight1.print(altitude);
  flight1.print(" m\tt: ");
 // Serial.print( temp.temperature );
 flight1.print(" deg C");
  flight1.print(Altitude);
  flight1.print("      ");
  flight1.println(Velocity);
  launch = 1;
Velocity = altitude_difference + 0.05/0.094;
 float Velocity_present = Velocity;
if (Maxvel <= 0) {
  if (Velocity_past > Velocity_present) {
float    Max_velocity = Velocity;
flight1.println(Max_velocity);
 Maxvel = 1;
   delay(30);
  //unsigned long currentTime = millis();
 // if (currentTime - previousTime >= eventInterval) {
    //previousTime = currentTime;
 if (launch>=1) {
 if (Apogee <= 1) {
  if (Velocity < 1.5) {
 launch = 2;
flight1.println ("Apogee");
//Serial.print ("    ");
//Serial.print (Altitude);
if(launch>=2) {
  if ( Velocity <= -1) {
flight1.print("      ");
flight1.print ("descent");
  flight1.print("      ");
Apogee = 2;
flight1.close();
Without even looking at your code, I can tell that you do not close the file before ending the program execution. Search the forum for the same problem with using an SD card.
Paul
Thanks for the reply,
I closed the file at the end of the sketch is this enough?
Your sketch indentation makes it really hard to read.
Apparently the file is closed only when a series of conditions are met.
Exactly when do you close the file? Does closing the file depend on a condition, like velocity<=-1, or it is always closed?
I use append.
void fSendToFile( void * parameter )
  if (!SD.begin())
    log_i("Card Mount Failed");
    xSemaphoreGive( sema_SD );
  String toFile = "";
  toFile.reserve( toFileSize );
  for (;;)
    if ( xQueueReceive(Q_toFIle, &toFile, portMAX_DELAY) == pdTRUE )
      //log_i( "%s %d\n", toFile.c_str(), toFile.length() );
      xSemaphoreTake( sema_SD, portMAX_DELAY );
      appendFile(SD, "/data.txt", toFile.c_str() + '\n');
      toFile = "";
    //log_i( " high watermark %d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete( NULL );
void writeFile(fs::FS &fs, const char * path, const char * message) {
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    log_i("Failed to open file for writing");
    return;
  if (file.print(message)) {
    log_i("File written");
    log_i("Write failed");
void appendFile(fs::FS &fs, const char * path, const char * message) {
  //log_i("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file)
    log_i("Failed to open file for appending");
    return;
    file.print(message);
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2) {
  log_i("Renaming file %s to %s\n", path1, path2);
  if (fs.rename(path1, path2)) {
    log_i("File renamed");
    log_i("Rename failed");
//void renameFile(fs::FS &fs, const char * path1, const char * path2) {
//  log_i("Renaming file %s to %s\n", path1, path2);
//  if (fs.rename(path1, path2)) {
//    log_i("File renamed");
//  } else {
//    log_i("Rename failed");
void deleteFile(fs::FS &fs, const char * path) {
  log_i("Deleting file: %s\n", path);
  if (fs.remove(path)) {
    log_i("File deleted");
    log_i("Delete failed");
