Trouble with Dual MPU9250 Library
Hello,
I am currently working on a head-movement wheelchair project and plan on using 2 MPU9250 to calculate the yaw difference and turn a motor to compensate for the difference when the "head" moves. I'm quite new to Arduino so pardon my inexperience.
I am facing a couple of problems trying to import the files (GitHub - kriswiner/MPU9250: Arduino sketches for MPU9250 9DoF with AHRS sensor fusion) as a library. The error message "Specified folder/zip file does not contain a valid library" pops up when I try using the Arduino's built-in library manager. Thus, I tried installing it manually, but no examples came up after I extracted the files so I tried making an example folder by moving the "Dual_MPU9250" file in it and moving all other files out, which worked but led to problems when compiling. I would assume that I did the manual installation wrongly and I hope someone can help me out. Thank you.
This is the error message I'm getting. Namely a conflicting declaration of the variable A12.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Dual_MPU9250_dual_Ladybug:85:7: error: conflicting declaration 'float A12'
float A12, A22, A31, A32, A33; // rotation matrix coefficients for Euler angles and gravity components
In file included from D:\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:258:0,
from sketch\Dual_MPU9250_dual_Ladybug.ino.cpp:1:
D:\Arduino\hardware\arduino\avr\variants\mega/pins_arduino.h:80:22: note: previous declaration as 'const uint8_t A12'
static const uint8_t A12 = PIN_A12;
C:\Users\Bao\Downloads\MPU9250Lib\MPU9250-master\Dual_MPU9250\Dual_MPU9250_dual_Ladybug\Dual_MPU9250_dual_Ladybug.ino: In function 'void setup()':
Dual_MPU9250_dual_Ladybug:199:28: error: 'myinthandler1' was not declared in this scope
attachInterrupt(intPin1, myinthandler1, RISING); // define interrupt for intPin output of MPU9250 1
Dual_MPU9250_dual_Ladybug:200:28: error: 'myinthandler2' was not declared in this scope
attachInterrupt(intPin2, myinthandler2, RISING); // define interrupt for intPin output of MPU9250 2
C:\Users\Bao\Downloads\MPU9250Lib\MPU9250-master\Dual_MPU9250\Dual_MPU9250_dual_Ladybug\Dual_MPU9250_dual_Ladybug.ino: In function 'void loop()':
Dual_MPU9250_dual_Ladybug:271:5: error: 'MadgwickQuaternionUpdate1' was not declared in this scope
MadgwickQuaternionUpdate1(-ax1, +ay1, +az1, gx1pi/180.0f, -gy1pi/180.0f, -gz1*pi/180.0f, my1, -mx1, mz1);
Dual_MPU9250_dual_Ladybug:316:5: error: 'MadgwickQuaternionUpdate2' was not declared in this scope
MadgwickQuaternionUpdate2(-ax2, +ay2, +az2, gx2pi/180.0f, -gy2pi/180.0f, -gz2*pi/180.0f, my2, -mx2, mz2);
Dual_MPU9250_dual_Ladybug:428:46: error: assignment of read-only variable 'A12'
A12 = 2.0f * (Q[1] * Q[2] + Q[0] * Q[3]);
C:\Users\Bao\Downloads\MPU9250Lib\MPU9250-master\Dual_MPU9250\Dual_MPU9250_dual_Ladybug\Dual_MPU9250_dual_Ladybug.ino: At global scope:
Dual_MPU9250_dual_Ladybug:481:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
That is not a library. It is a sketch. If you unzip the entire repo, you need to create a directory in your sketch folder called
'Dual_MPU9250_dual_Ladybug' and then put all those files in that folder: Dual_MPU9250_dual_Ladybug.ino, MPU9250.cpp, MPU9250.h and then just open the .ino file (or double click on it)
The Arduino IDE demands that the sketch filename match the directory that contains it.
