Trouble with Electric Door Lock Project
Hi there! I am working on an electric door lock system and my LCD won't display the text. I've tried using 2 other LCDs, rewiring, and testing out another code.
This is a picture of the wiring, the blue and black wires are not connected right now but they are supposed to connect to a solenoid.
This is the code:
#include <Keypad.h>
#include<LiquidCrystal.h>
#include<EEPROM.h>
LiquidCrystal liquid_crystal_display(9,8,7,6,5,4,);
char password[4];
char initial_password[4],new_password[4];
int i=0;
int relay_pin = 10;
char key_pressed=0;
const byte rows = 4;
const byte columns = 4;
char hexaKeys[rows][columns] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte row_pins[rows] = {A0,A1,A2,A3};
byte column_pins[columns] = {A4,A5,3,2};
Keypad keypad_key = Keypad( makeKeymap(hexaKeys), row_pins, column_pins, rows, columns);
  pinMode(relay_pin, OUTPUT);
  liquid_crystal_display.begin(16,2);
  liquid_crystal_display.print(" DIYhacking.com");
  liquid_crystal_display.setCursor(0,1);
  liquid_crystal_display.print("Electronic Lock ");
  delay(2000);
  liquid_crystal_display.clear();
  liquid_crystal_display.print("Enter Password");
  initialpassword();
  digitalWrite(relay_pin, HIGH);
  key_pressed = keypad_key.getKey();
  if(key_pressed=='#')
    change();
  if (key_pressed)
    password[i++]=key_pressed;
    liquid_crystal_display.print(key_pressed);
  if(i==4)
    delay(200);
    for(int j=0;j<4;j++)
      initial_password[j]=EEPROM.read(j);
    if(!(strncmp(password, initial_password,4)))
      liquid_crystal_display.print("Pass Accepted");
      digitalWrite(relay_pin, LOW);
      delay(2000);
      liquid_crystal_display.print("Pres # to change");
      delay(2000);
      liquid_crystal_display.print("Enter Password:");
      i=0;
      liquid_crystal_display.print("Wrong Password");
      liquid_crystal_display.print("Pres # to Change");
      delay(2000);
      i=0;
void change()
  int j=0;
  liquid_crystal_display.print("Current Password");
  while(j<4)
    char key=keypad_key.getKey();
    if(key)
      new_password[j++]=key;
      liquid_crystal_display.print(key);
    key=0;
  if((strncmp(new_password, initial_password, 4)))
    liquid_crystal_display.print("Try Again");
    j=0;
    liquid_crystal_display.print("New Password:");
    while(j<4)
      if(key)
        initial_password[j]=key;
        EEPROM.write(j,key);
        j++;
    liquid_crystal_display.print("Pass Changed");
  key_pressed=0;
void initialpassword(){
    EEPROM.write(j, j+49);
upload a schematic showing the wiring
how are you powering the devices?
Neither blue wire nor black wire is connected.
Why
All
The
Spaces
Between
Each
Line
Of
Code?
space
for
comments
in
the
future
Your code does not compile because there is an error on the line:
the comma after the 4 is wrong. need to remove it.
I tested your code in the simulator with the comma removed and
the message appeared on the LCD: Enter Password
In your assembly, nothing appears on the LCD?
