I am in need of assistance troubleshooting BLE. I have tried a combination of boards (ESP32 and Giga) and have not been able to get the slightly modified basic example to work (no connection established). Below is the central and peripheral code:
#include <ArduinoBLE.h>
// variables for button
int incomingByte = 0;
while (!Serial);
// configure the button pin as input
pinMode(buttonPin, INPUT);
// initialize the Bluetooth® Low Energy hardware
BLE.begin();
Serial.println("Bluetooth® Low Energy Central - LED control");
// start scanning for peripherals
BLE.scanForUuid("19B10001-E8F2-537E-4F6C-D104768A1214");
// check if a peripheral has been discovered
BLEDevice peripheral = BLE.available();
if (peripheral) {
// discovered a peripheral, print out address, local name, and advertised service
Serial.print("Found ");
Serial.print(peripheral.address());
Serial.print(" '");
Serial.print(peripheral.localName());
Serial.print("' ");
Serial.print(peripheral.advertisedServiceUuid());
if (peripheral.localName() != "LED") {
return;
// stop scanning
BLE.stopScan();
controlLed(peripheral);
// peripheral disconnected, start scanning again
BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214");
void controlLed(BLEDevice peripheral) {
// connect to the peripheral
Serial.println("Connecting ...");
if (peripheral.connect()) {
Serial.println("Connected");
Serial.println("Failed to connect!");
return;
// discover peripheral attributes
Serial.println("Discovering attributes ...");
if (peripheral.discoverAttributes()) {
Serial.println("Attributes discovered");
Serial.println("Attribute discovery failed!");
peripheral.disconnect();
return;
// retrieve the LED characteristic
BLECharacteristic ledCharacteristic = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1214");
if (!ledCharacteristic) {
Serial.println("Peripheral does not have LED characteristic!");
return;
} else if (!ledCharacteristic.canWrite()) {
Serial.println("Peripheral does not have a writable LED characteristic!");
return;
while (peripheral.connected()) {
if (Serial.available() > 0) {
incomingByte = Serial.read();
if (incomingByte != 10) {
Serial.print("byte: ");
Serial.println(incomingByte, DEC);
if (incomingByte == 49) ledCharacteristic.writeValue((byte)0x01);
else ledCharacteristic.writeValue((byte)0x00);
Serial.println("Peripheral disconnected");
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // Bluetooth® Low Energy LED Service
// Bluetooth® Low Energy LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLEByteCharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
const int ledPin = LED_BUILTIN; // pin to use for the LED
while (!Serial);
// set LED pin to output mode
pinMode(ledPin, OUTPUT);
// begin initialization
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
while (1);
// set advertised local name and service UUID:
BLE.setLocalName("LED");
BLE.setAdvertisedService(ledService);
// add the characteristic to the service
ledService.addCharacteristic(switchCharacteristic);
// add service
BLE.addService(ledService);
// set the initial value for the characeristic:
switchCharacteristic.writeValue(0);
// start advertising
BLE.advertise();
Serial.println("BLE LED Peripheral");
// listen for Bluetooth® Low Energy peripherals to connect:
BLEDevice central = BLE.central();
// if a central is connected to peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's MAC address:
Serial.println(central.address());
// while the central is still connected to peripheral:
while (central.connected()) {
// if the remote device wrote to the characteristic,
// use the value to control the LED:
if (switchCharacteristic.written()) {
if (switchCharacteristic.value()) { // any value other than 0
Serial.println("LED on");
digitalWrite(ledPin, HIGH); // will turn the LED on
} else { // a 0 value
Serial.println(F("LED off"));
digitalWrite(ledPin, LOW); // will turn the LED off
// when the central disconnects, print it out:
Serial.print(F("Disconnected from central: "));
BLE.scanForUuid("19B10000-E8F2-537E-4F6C-D104768A1214");
You have an error in the central code. You want to start scanning for the service uuid and not the characteristic uuid.
I have your peripheral sketch running on an ESP32 and the central on a Nano33BLE.
With the !Serial command, you will need both monitors open.
The monitor on the central is best set with no line ending.
The two sketches are working properly.
EDIT:
I have also switched the two devices around, and can run the sketches with the peripheral on the Nanol33BLE and the Central on the ESP32.
@MrY
The ArduinoBLE library is ported to the esp32. It is not necessary to use the BLE library bundled with the exp32 core. It may be preferable to use the exp32 core library and its syntax on an esp32, but ArduinoBLE will work on an esp32.
@cattledog Thank you for your response. Could you please cite the incorrect code and what it should be? From the looks of my code, it appears that I am scanning for the service UUID.
I was able to get it working briefly but after awhile the connection stopped establishing. Is there something wrong with the code below?
while (!Serial);
BLE.begin();
if (peripheral) {
Serial.print(" '");
Serial.print("' ");
return;
// stop scanning
BLE.stopScan();
return;
return;
return;
return;
if (incomingByte == 119 || incomingByte == 115 || incomingByte == 97 || incomingByte == 100)
ledCharacteristic.writeValue(incomingByte);
while (!Serial);
if (!BLE.begin()) {
while (1);
// add service
BLE.advertise();
if (central) {
if (switchCharacteristic.value() == 119) { // any value other than 0
Any further recommended troubleshooting steps for ESP32 boards? Additionally, when uploading the code to Giga boards I get this error:
/Users/marcofusco/Documents/Arduino/libraries/ArduinoBLE/src/BLECharacteristic.h:79:7: note: candidate: int BLECharacteristic::writeValue(int32_t, bool)
int writeValue(int32_t value, bool withResponse = true);
Using library ArduinoBLE at version 1.3.7 in folder: /Users/marcofusco/Documents/Arduino/libraries/ArduinoBLE
exit status 1
Compilation error: call of overloaded 'writeValue(int&)' is ambiguous
I have run your two sketches and they stayed connected for over 12 hours. An esp32 was the peripheral, and a Nano 33 is the central.
I have two open instances of the ide, and the connection process may be more reliable if you start the peripheral sketch first, and open the monitor for it. Then the Central can find and connect to it when its monitor is opened.
