I am trying to use the debounce sketch off arduino site. I have tested it on arduino uno board and it toggles the led off and on.
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = HIGH; // the current state of the output pin
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
// set initial LED state
digitalWrite(ledPin, ledState);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited long enough
// since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
// set the LED:
// save the reading. Next time through the loop, it'll be the lastButtonState:
lastButtonState = reading;
I am trying to combine it with the datalogging code to record three sensors. I tested this sketch separately also. It works too.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
I tried multiple combinations but I am not getting any where. I put the codes as original without the starting comments.
My goal is to push the button on breadboard, start recording the data from the sensors then push the button again and it stops recording and closes sd card file. Any help stepping me through where I need to put the parts would be greatly appreciated.
Where exactly is the problem? I don't see any conflicts. Of course you can't just copy and paste the two sketches into a new sketch, you can only have one setup and loop function. You need to copy the code within each of these functions and combine them.
I combined the code. The error I am experiencing is that I get the code to start by pushbutton. It stays on and then immediately turns off. During that time I verified, I get a sd stored file of what is printed in serial. It was only a couple of lines.
I am not able to turn off by pushbutton because it is already off.
Debounce
#include <SPI.h>
#include <SD.h>
dataString += ",";
if (dataFile) {
dataFile.close();
else {
// set the LED:
Start with your lastDebounceTime in lines 58 thru 63. If there is a change of state, you set lastDebounceTime to millis() and then in the immediate next statement perform a test where you subtract what you just set to millis from millis, which will result is a few clock cycles or 1ms as is the resolution of millis but in all likelihood the answer you'll get is zero. This of course is never going to be greater than 50.
This is my current code. The SD card initializes and waits.. I push the button and it starts to read analog inputs but only gets to readings. Then it closes the data file. I am wanting the for loop recording the data to sd card to run continuously until the button is pushed again.
Debounce
#include <SPI.h>
#include <SD.h>
dataString += ",";
if (dataFile) {
dataFile.close();
else {
// set the LED:
