I am trying to create a heart beat using a relay + light and I can't have a delay because I am using a ping sensor and motor to make the heart beat faster and sculpture vibrate as you get closer. This is for a sculpture I am doing and my professor and I have tried many ways but can't seem to get it to work. All I need is the relay heart heart beat code and what I would I would map. I can do the rest.
I assume that you have seen the BlinkWithoutDelay example in the IDE. Modify it like this
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
interval = longValue;
ledState = LOW;
interval = shortValue;
Choose appropriate values for longValue and shortValue to suit your needs.
This is what I have so far, using your code. I get no blinking at all.
// constants won't change. Used here to
// set pin numbers:
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
Serial.print(interval);
Serial.print(" ");
Serial.print(currentMillis - previousMillis);
Serial.print(" ");
Serial.println(ledState);
//if(currentMillis - previousMillis > 1000) {
if(currentMillis - previousMillis > interval)
// save the last time you blinked the LED
ledState = HIGH;
interval = 1000;
ledState = LOW;
interval = 700;
Look at the last few lines in the BlinkWithoutDelay example in the IDE. You forgot to include the digitalWrite function to actually change the state of the pin.
// set pin numbers:
boolean ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0; // will store last time LED was updated
unsigned long interval = 1000; // interval at which to blink (milliseconds)
// blink the LED.
Serial.print(" ");
Serial.print(" ");
if (currentMillis - previousMillis > interval) {
ledState = !ledState;
digitalWrite(ledPin, HIGH);
interval = 100;
digitalWrite(ledPin, LOW);
interval = 1000;
If you specify what you need it would far more easy to help you. So attach a timing diagram or a state diagram. Also you should do this in the first place since it helps you structure your code
Thanks. I had fun doing it. I was amazed by how much code I could take out by using the arrays, the modulo operator and sneaky stuff like incrementing the state as part of the digitalWrite() and doing the modulo as part of the array index, although that is starting to border on making the code unreadable and in practice would probably be better as separate statements.
