int led[4][4]={{2,3,4,5},{6,7,8,9}};
for(int i = 2; i<=10;i++)
pinMode(i,OUTPUT);
for(int rows = 2; rows <= 5; rows++)
for(int colums = 6; colums <= 9; colums++)
digitalWrite(led[rows][colums],HIGH);
digitalWrite(led[rows][colums],LOW);
this is my code what am i doing wrong?
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
int led[4][4]={{2,3,4,5},{6,7,8,9}};0
This array has 4 rows numbered 0 to 3 and 4 columns numbered 0 to 3
Your for loops use values from 2 to 5 and 6 to 9 as the array index values so are accessing memory outside of the array
gcjr
4
look this over
output
0 1 2
10 11 12
20 21 22
30 31 32
40 41 42
const int Nrow = 5;
const int Ncol = 3;
int matrix [5][3] = {
{ 0, 1, 2 },
{ 10, 11, 12 },
{ 20, 21, 22 },
{ 30, 31, 32 },
{ 40, 41, 42 },
void setup ()
Serial.begin (9600);
for (int row = 0; row < Nrow; row++) {
for (int col = 0; col < Ncol; col++) {
Serial.print (" ");
Serial.print (matrix [row][col]);
Serial.println ();
void loop () {
What exactly are you trying to do? is it a 4x4 array of LEDs or a 2x4 array?
This {{2,3,4,5},{6,7,8,9}}; is 2x4
Arrays also start at 0 index so both of your for loops are incorrect.
You also have a single delay instead of another after you turn off the LEDs.
Try this instead.
for(int row = 0; row < 2; row++) {
for(int column = 0; column < 4; column++) {
digitalWrite(led[row][column],HIGH);
digitalWrite(led[row][column],LOW);
J-M-L
6
either you use the pins in the array, or you just use the for loops indexes as PIN numbers
for the setup it would be like this
for(int i = 2; i<=10;i++) pinMode(i,OUTPUT); // pin D2 to D10 as output
