Trying to map two motors onto a joystick
So for this project I'm working on I'm trying to map out two motors onto a single joystick using two L293D H-bridges, I feel like there is something in my code that I'm missing here. I tried modeling this off of the sketch from Jeremy Blum's Exploring Arduino book from page 78, however this sketch uses a potentiometer instead of a joystick but I feel the general aspects should carry over. I also need yet to map out the x-axis of the joystick input to enable turning.
#include <Wire.h>
#include <Servo.h>
// i2c address of the mpu‐6050
const int MPU_ADDR = 0x68;
// variables
int16_t xAccel, yAccel, zAccel, temp, xGyro, yGyro, zGyro;
const int TILT = 9;
const int G = 10;
Servo myServo;
Servo Myservo;
int val = 0;
int v = 0;
int VRy = A1; // Read Analog value
int VRx = A0;
int SW = 12;
int yPos = 0;
int xPos = 0;
signed char SW_state = 0;
signed char mapY = 0; // This will be used for mapping the values to limited values for deciding position
signed char mapX = 0;
const int EN  = 5; // right side
const int MC1 = 8;
const int MC2 = 2;
const int EN2 = 3; //left side
const int MC3 = 4;
const int MC4 = 7;
int velocity = 0;
  // initialize the i2c library
  Wire.begin();
  // begin communication with the mpu‐6050
  Wire.beginTransmission(MPU_ADDR);
  // write to the power management register
  Wire.write(0x6B);
  // wake up the mpu‐6050
  Wire.write(0);
  // end communication with the mpu‐6050
  Wire.endTransmission(true);
  // initialize the serial port
  myServo.attach(TILT);
  Myservo.attach(G);
pinMode(VRy, INPUT);
pinMode(VRx, INPUT);
pinMode(SW, INPUT_PULLUP);
//constrain(mapY, -512,512);
//constrain(mapX, -512, 512);
pinMode(EN, OUTPUT);
pinMode(MC1, OUTPUT);
pinMode(MC2, OUTPUT);
pinMode(EN2, OUTPUT);
pinMode(MC3, OUTPUT);
pinMode(MC4, OUTPUT);
brake();
  // read the mpu data
  //readMpuData();
     * put your code for the digital letter scale here
       // delay
  //delay(500);
       // write to the first data register
  Wire.write(0x3B);
  Wire.endTransmission(false);
        // request fourteen register reads from the mpu‐6050
  Wire.requestFrom(MPU_ADDR, 14, true);
        // read registers 0x3B (ACCEL_XOUT_H) and 0x3C (ACCEL_XOUT_L)
  xAccel  = Wire.read() << 8 | Wire.read();
        // read registers 0x3D (ACCEL_YOUT_H) and 0x3E (ACCEL_YOUT_L)
  yAccel  = Wire.read() << 8 | Wire.read();
        // read registers 0x3F (ACCEL_ZOUT_H) and 0x40 (ACCEL_ZOUT_L)
  zAccel  = Wire.read() << 8 | Wire.read();
       // read registers 0x41 (TEMP_OUT_H) and 0x42 (TEMP_OUT_L)
  temp   = Wire.read() << 8 | Wire.read();
       // convert the temperature to celsius
  temp   = ((temp / 340.00) + 36.53);
       // read registers 0x43 (GYRO_XOUT_H) and 0x44 (GYRO_XOUT_L)
  xGyro = Wire.read() << 8 | Wire.read();
        // read registers 0x45 (GYRO_YOUT_H) and 0x46 (GYRO_YOUT_L)
  yGyro = Wire.read() << 8 | Wire.read();
        // read registers 0x47 (GYRO_ZOUT_H) and 0x48 (GYRO_ZOUT_L)
  zGyro = Wire.read() << 8 | Wire.read();
        // print out the results
  Serial.print("AX = "); Serial.print(xAccel); // X Raw Value
  Serial.print(" | AY = "); Serial.print(yAccel); // Y Raw Value
  Serial.print(" | AZ = "); Serial.print(zAccel); // Z Raw Value
       Serial.print(" |  C = "); Serial.print(temp);
       Serial.print(" | GX = "); Serial.print(xGyro);
       Serial.print(" | GY = "); Serial.print(yGyro);
       Serial.print(" | GZ = "); Serial.println(zGyro);
       delay(50);
  yAccel = map(yAccel, 750, 11000, 0, 190);
  myServo.write(yAccel);
  delay(50);
  if (val > 0){
    Myservo.write(90);
    delay(10);
  else if (val = 0){
    Myservo.write(0);
    delay(10);
yPos = analogRead(VRy);
xPos = analogRead(VRx);
   if (yPos > 562){
    velocity = map(yPos, 563, 1023, 0, 255);
    forward(velocity);
  else if (yPos < 462){
    velocity = map(yPos, 461, 0, 0, 255);
    reverse(velocity);
  else{
    brake();
  //yPos = analogRead(VRy); // This will read Vertical Motion value
//SW_state = digitalRead(SW);
//mapY = map(yPos, 0, 1023, -512, 512); // here joystic's mean position is 512 which is mapped to 0
                         // position 0 (Extreme bottom) is mapped to -512
                         // position 1023 (Extreme Up) is mapped to 512
void readMpuData()
void forward (int rate)
  digitalWrite(EN, LOW);
  digitalWrite(MC1, HIGH);
  digitalWrite(MC2, LOW);
  analogWrite(EN, rate);
  digitalWrite(EN2, LOW);
  digitalWrite(MC3, HIGH);
  digitalWrite(MC4, LOW);
  analogWrite(EN2, rate);
void reverse (int rate)
  digitalWrite(MC1, LOW);
  digitalWrite(MC2, HIGH);
  digitalWrite(MC3, LOW);
  digitalWrite(MC4, HIGH);
void brake ()
  digitalWrite(EN, HIGH);
  digitalWrite(EN2, HIGH);
Sorry but when I see two servos called myServo and Myservo I stop reading. That's a clear recipe for confusing the hell out of anyone trying to read the code and probably you when you come back to it later. And your program has a lot of complexity that has nothing to do with joysticks or motors.
Why not write a simpler program without servos and accelerometer that just controls the motors with the joystick and see if you still have problems? If you do then post that program and give a lot more detail of exactly what the problems are.
Steve
Kind of confusing, are the two motors two servos? Servos are easy to control with pot based joysticks.
