So I'm trying to move this array of leds on a LED strip. I have 162 leds on my 2812 strip. Below is a snippet of my code. The code lights up 4 groups of 5 LEDS on the strip. What I'm wanting to do is move them all to the left 10 spots and all to the right 10 spots simutaneosly. I don't know where to start. Been scouring online and the forum and am lost. Any advice? Thanks!
int myBases[ ] = {14,15,16,17,18, 60,61,62,63,64, 97,98,99,100,101, 143,144,145,146,147}; //address of LED's to be passed into the for loop
int b;
TouchThemAll();
void TouchThemAll()
FastLED.clear();
Bases();
void Bases() {
for (b = 0; b < 20; b++) //To me this says, turn every led on at led[i address]
leds[myBases[b]] = CRGB::White;
FastLED.show();
So here is my complete sketch. I'm not able to get the arrays of leds to simultaneosly shift over 4 spots then back. to the original position.
When its loaded to the arduino, the leds light up 4 spots over from their array position. What I'm wanting is an animation for them all to shift over 4 spots then back and repeat. Sorry I wasn't more clear....Any suggestions?
#include "FastLED.h"
#define NUM_LEDS 50
#define DATA_PIN 5
//#define CLOCK_PIN 13
int myBases[ ] = {7,8,9,10, 17,18,19,20, 28,29,30,31, 39,40,41,42}; //address of LED's to be passed into the for loop
int b;
#define n 4
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
TouchThemAll();
void TouchThemAll()
FastLED.clear();
Bases();
void Bases() {
for (b = 0; b < 16; b++) //To me this says, turn every led on at led[i address]
leds[myBases[b]+n] = CRGB::White;
delay(20);
leds[myBases[b]-n] = CRGB::White;
delay(20);
FastLED.show();
Note that in my examples I never check if the leds array indices are valid, so in your code make sure to add protection to never read or write outside of the leds array
GUIX: Thanks again man! One last question: if i just wanted to run the sequence say 5 times for example, would it look something like this below? Sorry not in front of my setup at the moment so I'm thinking out loud...
#define NUM_PATTERN1 5
for (int i = 0; i < NUM_PATTERN1; i++) {
pattern1();
void pattern1()
//your code:
for ( uint8_t i = 0; i < basesCount; i++ )
for ( uint8_t j = basesStart[i], k = j + basesLength; j < k; j++ )
leds[j] = CRGB::White;
