Understood. And you have plenty of advices for how to get further along with this, sorta been tots tossed into the deep end with this, do not fear.
If some pages long tutorials suit you, fine. otherwise ignore them. Do not be intimidated, it is not that hard to grasp.
It would be best if you decided the full function of a very small program.
Obvsly here you want an anticlockwise sweep when two buttons are down. Or clockwise - I just like any excuse to use "anticlockwise"
Your original code will initiate a sweep the instant it sees the two buttons down, and continue blind to input until the sweep is done.
What then? What if the buttons are still down? What will make it sweep the opposite direction?
When you use the various tricks talked about above, you will have to (be able to!) think about things differently, things like:
Sweep left while both buttons are down. STOP if either goes up during. If the either button goes down again (both?) sweep back to a resting position. Or maybe one button means continue to the other extreme, and the other means go back to home. Something could happen if one button goes up - slow down, perhaps.
As with any program, it is up to you to decide.
With all this opportunity comes the necessity of specifying what happens when and for why. Anything you do not deliberately plan for will nevertheless have some outcome in the code. The more you plan, the fewer surprises. One should never be surprised by the behaviour of the code, certainly not in a tiny program.
So write up a little description of how two buttons might want to control one servo. Do this with or without your ultimate objective in mind, but make it be something you can write, test and get help with here perfecting, independent of any larger context (the big project) you might want to insert it in directly.
Then you can use the techniques you get the hang of in isolation to write sections of wonderful non-blocking state machine orientated code for your big project.
Speaking of which, your big project may need re-working itself if it also has any blocking or other unfortunate expressions of your desires (code) that frustrates or invalidates the use of millis() in the way we aiming you at.
Which is why I repeat - get some small project, very small, working using these techniques before you come within a kilometer of using them in your real project.
a7
