Trying to use the analog comparator to interrupt past a certain voltage
Hello, I am trying to use the analog comparator on an Arduino Uno to trigger an interrupt when I hit a voltage of > 3.3 volts on a rising edge. I am able to trigger on a rising edge but it seems to ignore my AIN1 voltage level and will always interrupt even when I have 2.1v on my AIN0 input. I have to use the analog comparator due to my timing of my system. My code is as followed:
#include <avr/interrupt.h>
#define DELAYTIME 500
bool pinStatus = false;
double lastTime = 0;
volatile bool analogTrigger = false;
  pinMode(A0, OUTPUT);
  pinMode(3, INPUT);
  //Set up the interrupts for the analog Comparator
  ADCSRB = 0;           // (Disable) ACME: Analog Comparator Multiplexer Enable
  ACSR = bit (ACIE)      // (Clear) Analog Comparator Interrupt Flag
         | bit (ACIE)    // Analog Comparator Interrupt Enable
         | bit (ACIS1)  // ACIS1, ACIS0: Analog Comparator Interrupt Mode Select (trigger on falling edge)
         | bit (ACIS0);
  int value = digitalRead(3);
  if (value == HIGH && (millis() - lastTime) > DELAYTIME)
    if (pinStatus)
      digitalWrite(A0, HIGH);
      pinStatus = false;
    else {
      digitalWrite(A0, LOW);
      pinStatus = true;
    lastTime = millis();
  if (analogTrigger) {
    Serial.println("High");
//the ISR that handles the analog compare interrupt
ISR(ANALOG_COMP_vect)
  analogTrigger = true;
Does anyone have any ideas what is going on?
I am using a voltage divider on pin A0 to give myself a 2.1V (Using it as a digital pin) signal to test the system right now. Also, I am using pin 3 as a push button to toggle my 2.1V input. Some of my code for the comparator I found from another post and I am using it temporarily so I can get it working then I plan on fixing that section up.
Thank you!
millis() does NOT return a double.
