Can any body help me with problem. I want to create a water monitoring. So this system monitor the PH-Value, temperature and turbidity. My problem is If I added a code related to firebase. The Turbidity Sensor always Give 0 as output. If I remove the Firebase related codes. It works properly. Does anybody have an Idea how to fix it. Please...
#include <OneWire.h>
#include <DallasTemperature.h>
#include "DFRobot_ESP_PH.h"
#include "EEPROM.h"
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
/* 1. Define the WiFi credentials */
#define WIFI_SSID "ESP_32"
#define WIFI_PASSWORD "12345678"
/* 2. Define the API Key */
#define API_KEY "AIzaSyDAGXq17jBhBuPA1FkjTWiBViWh7XhylwU"
/* 3. Define the RTDB URL */
#define DATABASE_URL "https://fishmanagement-1ab6e-default-rtdb.firebaseio.com/"
/* 4. Define the user Email and password that already registered or added in your project */
#define USER_EMAIL "admin@gmail.com"
#define USER_PASSWORD "password"
// Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
DFRobot_ESP_PH ph;
#define ESPADC 4096.0 //the esp Analog Digital Convertion value
#define ESPVOLTAGE 3300 //the esp voltage supply value
#define PH_PIN 35
float phvoltage, phValue, temperature = 25;
#define SENSOR_PIN 19
OneWire oneWire(SENSOR_PIN);
DallasTemperature DS18B20(&oneWire);
float tempC; // temperature in Celsius
float tempF; // temperature in Fahrenheit
float tVoltage;
float turbidityValue;
#define BUTTON_PIN 15
#define LED_PIN 17
#define TURBIDITY_PIN 13
bool buttonState = false;
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(27,25,12); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
DS18B20.begin();
EEPROM.begin(32);
ph.begin();
Rtc.Begin();
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the user sign-in credentials */
auth.user.email = USER_EMAIL;
auth.user.password = USER_PASSWORD;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
// Comment or pass false value when WiFi reconnection will control by your code or third party library e.g. WiFiManager
Firebase.reconnectNetwork(true);
// Since v4.4.x, BearSSL engine was used, the SSL buffer needs to be set.
// Large data transmission may require a larger RX buffer, otherwise connection issue or data read timeout can be occurred.
fbdo.setBSSLBufferSize(4096 /* Rx buffer size in bytes from 512 - 16384 */, 1024 /* Tx buffer size in bytes from 512 - 16384 */);
// Limit the size of response payload to be collected in FirebaseData
fbdo.setResponseSize(2048);
Firebase.begin(&config, &auth);
Firebase.setDoubleDigits(5);
config.timeout.serverResponse = 10 * 1000;
// Setup button and LED pins
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
tVoltage = analogRead(TURBIDITY_PIN);
turbidityValue = tVoltage * (5.0 / 1024.0);
Serial.print("Turbidity: ");
Serial.println(turbidityValue);
// Read button state
bool newButtonState = digitalRead(BUTTON_PIN);
// Check if button state has changed
if (newButtonState != buttonState) {
delay(50); // Debounce
if (newButtonState == LOW) { // Button is pressed
sendDataToFirebase();
buttonState = newButtonState;
// Blink LED if data is being sent
if (Firebase.ready() && newButtonState == LOW) {
digitalWrite(LED_PIN, !digitalRead(LED_PIN)); // Toggle LED
delay(500); // Blink interval
digitalWrite(LED_PIN, HIGH); // Turn off LED
delay(100); // Adjust delay as needed
void sendDataToFirebase() {
DS18B20.requestTemperatures(); // send the command to get temperatures
tempC = DS18B20.getTempCByIndex(0); // read temperature in °C
tempF = tempC * 9 / 5 + 32; // convert °C to °F
phvoltage = analogRead(PH_PIN) / ESPADC * ESPVOLTAGE;
phValue = ph.readPH(phvoltage, temperature);
RtcDateTime now = Rtc.GetDateTime();
char dateTimeString[20];
printDateTime(now, dateTimeString); // Get date and time string
//Serial.print("Temperature (F): ");
//Serial.println(tempF);
// Firebase.ready() should be called repeatedly to handle authentication tasks.
if (Firebase.ready())
String firebasePath = "/SensorData/" + String(dateTimeString) + "/";
if(Firebase.RTDB.setFloat(&fbdo, firebasePath + "Temperature", tempC)){
Serial.print("Temperature (C): ");
if(Firebase.RTDB.setFloat(&fbdo, firebasePath + "PH Value", phValue)){
Serial.print("PH Value ");
Serial.println(phValue);
if(Firebase.RTDB.setFloat(&fbdo, firebasePath + "Turbidity", turbidityValue)){
delay(2000); // Delay for 2 seconds after sending data
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt, char* dateString)
snprintf_P(dateString,
20,
PSTR("%02u-%02u-%04u %02u:%02u:%02u"),
dt.Day(),
dt.Month(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
