Hello , I'm new to arduino . I have a project that consists of using my music to use in any DAW keyboard music sequencer .
Take the idea of a video
but by using the code does not give me the notes in order. use a matrix of 8 x 7 , and only Use a shiftregister ( 74hc595 ) if someone could explain me that can be modified to work properly, thank you # do not use the midi output as the video I send serial data to a program that interprets ( hairles midi )
My code is
#define NUM_ROWS 7
#define NUM_COLS 8
#define NOTE_ON_CMD 0x90
#define NOTE_OFF_CMD 0x80
#define NOTE_VELOCITY 127
//MIDI baud rate
#define SERIAL_RATE 9600
// Pin Definitions
// Row input pins
const int row7Pin = 2;
const int row6Pin = 3;
const int row5Pin = 4;
const int row4Pin = 5;
const int row3Pin = 6;
const int row2Pin = 7;
const int row1Pin = 8;
// 74HC595 pins
const int dataPin = 9;
const int latchPin = 10;
const int clockPin = 11;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS];
// bitmasks for scanning columns
int bits[] =
B00000001,
B00000010,
B00000100,
B00001000,
B00010000,
B00100000,
B01000000,
B10000000
int note = 31;
for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
keyPressed[rowCtr][colCtr] = false;
keyToMidiMap[rowCtr][colCtr] = note;
note++;
// setup pins output/input mode
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(row1Pin, INPUT);
pinMode(row2Pin, INPUT);
pinMode(row3Pin, INPUT);
pinMode(row4Pin, INPUT);
pinMode(row5Pin, INPUT);
pinMode(row6Pin, INPUT);
pinMode(row7Pin, INPUT);
Serial.begin(SERIAL_RATE);
for (int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
//scan next column
scanColumn(colCtr);
//get row values at this column
int rowValue[NUM_ROWS];
rowValue[0] = digitalRead(row1Pin);
rowValue[1] = digitalRead(row2Pin);
rowValue[2] = digitalRead(row3Pin);
rowValue[3] = digitalRead(row4Pin);
rowValue[4] = digitalRead(row5Pin);
rowValue[5] = digitalRead(row6Pin);
rowValue[6] = digitalRead(row7Pin);
// process keys pressed
for(int rowCtr=0; rowCtr<NUM_ROWS; ++rowCtr)
if(rowValue[rowCtr] != 0 && !keyPressed[rowCtr][colCtr])
keyPressed[rowCtr][colCtr] = true;
noteOn(rowCtr,colCtr);
// process keys released
if(rowValue[rowCtr] == 0 && keyPressed[rowCtr][colCtr])
noteOff(rowCtr,colCtr);
void scanColumn(int colNum)
digitalWrite(latchPin, LOW);
if(0 <= colNum && colNum <= 8)
shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //right sr
shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum]); //left sr
shiftOut(dataPin, clockPin, MSBFIRST, bits[colNum-8]); //right sr
shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //left sr
digitalWrite(latchPin, HIGH);
void noteOn(int row, int col)
Serial.write(NOTE_ON_CMD);
Serial.write(keyToMidiMap[row][col]);
Serial.write(NOTE_VELOCITY);
void noteOff(int row, int col)
Serial.write(NOTE_OFF_CMD);
