Turn on/off relay
I'm trying to turn a relay on and off, from a program I made in C#. Me When I click on the button I see the "RX" led of the ArduinoBoard turning on, that is, something comes to the Arduino, but the relay never comes on... I don't know what I'm doing wrong
C# Code
Class forms:
private void ACClick_Click(object sender, EventArgs e)
        if (AC)
            Arduino.SendInfo(Convert.ToString(AC));
            this.ArCondicionado.BorderStyle = BorderStyle.FixedSingle;
            AC = false;
            this.ArCondicionado.BorderStyle = BorderStyle.None;
            AC = true;
Class to control my arduino info:
 class Arduino
    static SerialPort Port;
    public static int ConnectArduino()
        int ArduinoPort = 0;
        try
            if (Port == null)
                Port = new SerialPort();
                Port.PortName = "COM3";//Set your board COM
                Port.BaudRate = 9600;
                Port.Open();
                ArduinoPort = 1;
        catch (Exception e)
            Console.WriteLine("{0} Exception caught.", e);
            MessageBox.Show("O Arduino not connected", "Erro", MessageBoxButtons.OK, MessageBoxIcon.Error);
        return ArduinoPort;
   public static void SendInfo(string message)
        try
            if (Port != null && Port.IsOpen)
                Port.Write(message);
                Console.WriteLine(message);
        catch (Exception e)
            Console.WriteLine("Exception information: {0}", e);
            throw new Exception(e.ToString());
Arduino code:
 #include "ArduinoJson.h"
  StaticJsonDocument<200> doc;
  #define relayO 7
    pinMode(relayO, OUTPUT);
    digitalWrite(relayO, HIGH);
    if (! Serial.available()) return;
    String json = Serial.readString();
    deserializeJson(doc, json);
    JsonVariant RelayInfo = doc["AC"];
    if(!RelayInfo.isNull()) {
      if(RelayInfo=="True") {
        digitalWrite(relayO,HIGH);
      else{
        digitalWrite(relayO,LOW);
Have you tried printing what the Arduino receives ?
Is it what you expect ?
verify that the code can toggle the realy
    while (1)  {
        delay (1000);
        delay (1000);
and as bob suggested, verify what is received
Receives a json with an object "AC" that has an assumed value (true or false but the type is a string).
I can't open the serial port in arduino IDE and connect to arduino (with my c# code), because it don't let's me use the same COM port on 2 different things. I don't know if I'm making myself understood
The relay is working I made a code similar to that was working fine. The problem is the Arduino interpret the information receives
