Hey guys,
For a project I'm trying to create a GPS-tracker with an Arduino Uno, the Arduino GSM Shield and the Adafruit ultimate GPS-logging shield. So far I've managed to write a few scripts that address parts of the required functionality, however when I add these scripts together I run out of space both memory-wise and ram-wise. Could anyone advise me on how to solve this problem?
The goal of the gps-tracker is to log the gps data and save this on an SD card. The gps data is then read from this file and is being send through a http post request.
I've added the code separately (due to character size limit). It is the combined script that takes roughly 106% storage space and 120% memory space. I've already tried to comment out the serial println statements, to reduce the library size (which I failed at terribly) and I've also tried to build the configuration with an Arduino Mega. With the Arduino Mega however I ran into problems that first I had to connect ports with jumber cables, and that I could not get the code to run properly on it at all. I've also removed the server url due to privacy concerns.
I've added th
code.txt (10.4 KB)
