Turning on a fan using millis() function only
Can someone help me up with a code; I am trying to run a fan for 10 seconds after every 10 minutes without using delay function as it put the whole code on hold and have failed to come up with a logic using only millis() function
Hello osamaaftab2
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
What have you tried so far?
Have you studied this famous example?
https://www.arduino.cc/en/Tutorial/BuiltInExamples/BlinkWithoutDelay
For further study:
https://www.forward.com.au/pfod/ArduinoProgramming/TimingDelaysInArduino.html
This works on Nano, maybe too simple?
unsigned long timer,
              cycleTime = 600000; // ten minutes
const int onTime = 10000; // ten seconds
const byte fanPin = 2;
  //Serial.begin(9600);
  pinMode(fanPin,OUTPUT);
  if(millis() - timer >= cycleTime)
    timer += cycleTime; // add cycleTime to timer for next event
  digitalWrite(fanPin,millis() - timer < onTime); // ON for first 10 seconds of cycle
NOTE You cannot run a fan directly from an Arduino output pin, you need a relay or transistor to handle the motor current.
Try the following sketch -- tested using L (On for 1-sec and OFF for 2-sec) using millis() function.
unsigned long prMillis = 0;
byte ledState = HIGH;
bool flag = false;
  pinMode(13, OUTPUT);
  digitalWrite(13, ledState);   //LED is ON
  flag = true;
  prMillis = millis();
  if (flag == true)
    if (millis() - prMillis >= 1000)//1-sec is over
      ledState = !ledState;
      digitalWrite(13, ledState); //LED is OFF
      flag = false;
    if (millis() - prMillis >= 2000)//2-sec is over
      flag = true;
Hello osamaaftab2
Try this modified BLINKWITHOUT example from IDE.
// constants won't change. Used here to set a pin number:
const int ledPin =  LED_BUILTIN;// the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time LED was updated
// constants won't change:
const unsigned long interval[] {600000,10000};  // 10min/10sec
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the difference
  // between the current time and last time you blinked the LED is bigger than
  // the interval at which you want to blink the LED.
  if (currentMillis - previousMillis >= interval[ledState]) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
