Hi all.
Background:-
I have my HTPC connected to my Tv via HDMI. However, when the Tv is switched off Windows7 on the HTPC will drop down to a different resolution, or indeed cause other issues. An I2C bus between the Tv and HTPC is where this all happens.
I have built a wee interface so that the Arduino will replace the Tv I2C as the slave device (HTPC is master).
Problem:-
I just can't get the Arduino to react to the HTPC.
I've checked the I2C connections, and verified that the slave address should be 6E.
I've played with Arduino's as Master devices but never slave.........so here's the code, just wondered if anyone can see anything wrong. Basically, the requestEvent is never called.
// EDID Keeper V1.0
// For use with Arduino Nano
// Ian Johnston 18/12/2010
#include <Wire.h> // include Wire library for I2C
int ledpin=13;
int i=0;
// EDID data to send (Panasonic Tv), 128 bytes. Captured using PowerStrip or Read-EDID apps.
// 00 FF FF FF FF FF FF 00 34 A9 96 A0 01 01 01 01
// 00 13 01 03 80 00 00 78 0A DA FF A3 58 4A A2 29
// 17 49 4B 00 00 00 01 01 01 01 01 01 01 01 01 01
// 01 01 01 01 01 01 02 3A 80 D0 72 38 2D 40 10 2C
// 45 80 BA 88 21 00 00 1E 02 3A 80 18 71 38 2D 40
// 58 2C 45 00 BA 88 21 00 00 1E 00 00 00 FC 00 50
// 61 6E 61 73 6F 6E 69 63 2D 54 56 0A 00 00 00 FD
// 00 17 3D 0F 44 0F 00 0A 20 20 20 20 20 20 01 E2
int EDIDArray[128]={
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x34,0xA9,0x96,0xA0,0x01,0x01,0x01,0x01,
0x00,0x13,0x01,0x03,0x80,0x00,0x00,0x78,0x0A,0xDA,0xFF,0xA3,0x58,0x4A,0xA2,0x29,
0x17,0x49,0x4B,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,
0x45,0x80,0xBA,0x88,0x21,0x00,0x00,0x1E,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,
0x58,0x2C,0x45,0x00,0xBA,0x88,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0xFC,0x00,0x50,
0x61,0x6E,0x61,0x73,0x6F,0x6E,0x69,0x63,0x2D,0x54,0x56,0x0A,0x00,0x00,0x00,0xFD,
0x00,0x17,0x3D,0x0F,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xE2
delay(500); // delay start
pinMode(ledpin, OUTPUT); // initialize as output
Wire.begin(0x6E); // join i2c bus with address 0x6E, slave mode
Wire.onRequest(requestEvent); // register event
//Serial.begin(9600); // start serial for output
digitalWrite(ledpin, LOW); // LED off
delay(1); // slow down main loop
void requestEvent() { // Executed in response to a request from the master (HTPC),
digitalWrite(ledpin, HIGH); // LED on when responding to request
for (i = 0; i < 128; i++) {
Wire.send(EDIDArray[i]);
delay(1);
//digitalWrite(ledpin, LOW); // LED off
