Two classes callback without static method
Hello!
I have two classes, ClassA needs to use ClassB, but ClassB has a callback whick needs to be a static method in ClassA, but if it is static I cannot reach ClassA's variables from that method. I tried it with lambda, but I canot figure out how to use it.
ClassA.h
class ClassA
    private:
        void (*clickFunc)();
    public:
        ClassA();
		void SetCallbacks(void (*clickFunc)());
ClassA.cpp
#include "ClassA.h"
ClassA::ClassA()
void ClassA::SetCallbacks(void (*clickFunc)())
    this->clickFunc = clickFunc;
void ClassA::something()
  clickFunc();
ClassB.h
class ClassB
  private:
	int asd;
	ClassA button;
        void ClassB::UpClick();
  public:
    ClassB();
ClassB.cpp
#include "ClassB.h"
ClassB::ClassB(): button()
  //button.SetCallbacks(UpClick); //needs to be static
  button.SetCallbacks([this](){this->UpClick();}); //got error
	this->asd = 0; //error if static
if you want class a to call class b then pass reference to class b to class a during class a initialisation, and then you will have class b methods available to class a
Ok, but I need two of classA in class B which needs to call separated methods.
which board are you writing for?
mega
What’s the point of having a callback tied to a member function. It needs to be static because it won’t be invoked as an instance call - just a class method call and thus won’t have access to whatever instance/member variables you might have in mind.
Just use a standard function for callback and ensure there is a way to tie that to a specific instance if needed
Is this what you are after?
class ClassB;
class ClassA
private:
	void(ClassB::*clickFunc)();
	ClassB* parent = nullptr;
public:
	ClassA() = delete;
	ClassA(ClassB* parent)
		: parent(parent)
	void SetCallback(void(ClassB::*clickFunc)())
	void ExecuteCallback()
		if (parent)
			(parent->*clickFunc)();
class ClassB
private:
	const char* up = "UP";
	const char* down = "DOWN";
public:
	ClassA button1;
	ClassA button2;
	ClassB()
		: button1{ this }, button2{ this }
		button1.SetCallback(&ClassB::UpClick);
		button2.SetCallback(&ClassB::DownClick);
	void UpClick()
		Serial.println(this->up);
	void DownClick()
		Serial.println(this->down);
	ClassB b;
	b.button1.ExecuteCallback();
	b.button2.ExecuteCallback();
I dont think this is the best design solution tbh
