How to stop led1 and power on led2 using millis
Your post was MOVED to its current location as it is more suitable.
Hello
By writing a sketch for an Arduino.
What have you tried and where are you stuck ?
Please post what you have tried
See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Yes sir, but i know how to use millis , i was stuck on the error where led 1 and led2 turns on at the same time. All i want is to turn one led1 for 2 seconds then off. Then turn on led2 while led1 is off
Please show us your current sketch at doing this.
Hello
Post your sketch to see how we can help.
That looks like for a OOP class based solution ![]()
So you don't know how to use millis() after all
Please post the code that you have a problem with
may be you want read this:
https://werner.rothschopf.net/microcontroller/202109_millis_two_leds_en.htm
Can you just post your code please?
If you will just post your code then we will be able to tell you if you "know how to use millis", If it turns out you don't then we can help you learn a bit more.
Steve
I guess the TO is sleeping and dreaming about a proper solution.
byte ledPins [] = { 10, 11 };
#define N_LEDS sizeof(ledPins)
#define TwoSec 2000
enum { LedOff = HIGH, LedOn = LOW };
unsigned long msecLst;
for (unsigned n = 0; n < N_LEDS; n++) {
digitalWrite (ledPins [n], LedOff);
pinMode (ledPins [n], OUTPUT);
msecLst = millis ();
digitalWrite (ledPins [0], LedOn);
unsigned long msec = millis ();
if (LedOn == digitalRead (ledPins [0]) && (msec - msecLst) > TwoSec) {
digitalWrite (ledPins [0], LedOff);
digitalWrite (ledPins [1], LedOn);
consider; I do like this note ![]()
// you may need to change these constants to your hardware
constexpr byte LED[] {2, 3};
enum {One, Two};
for (auto LED_ : LED) digitalWrite (LED_, LOW),pinMode(LED_, OUTPUT);
digitalWrite (LED[One], HIGH);
while (millis()<2000);
digitalWrite (LED[One], LOW);
digitalWrite (LED[Two], HIGH);
void loop () {}
Have a nice day and enjoy coding.
I'd correct the time handling, and dis-entangle it from the LED handling, ie change this:
to
if (msec - msecLst) > TwoSec)
msecLst = msec ; // you forgot to update this.
if (LedOn == digitalRead (ledPins [0]))
... something is presumably supposed to happen if LED 0 was off?
why? what's wrong with this?
not per the stated requriement
Separation of concerns is one of the important principles of programming. Mixing two different things into one line of code is less readable, less easy to maintain, and generally increases the entropy/chaos in the program.
Here's there's some logic to activate something at a given time or interval, there's also some business logic with LEDs. They are different things. And more importantly the time stuff is generically reusable in many situations - you might want to pull it off into a library or class to increase its reusability and simplify the business logic.
If its only supposed to happen once it probably belongs in setup(), not loop() ??
I do note the original code calls pinMode() after digitalWrite() - that's not guaranteed to work on every Arduino, pinMode should be set to OUTPUT before calling digitalWrite.
Other than that the original code seems plausible - is this a hardware issue then?
this is a novice user trying to do something trivial
this is my code
// assign pin numbers for the leds
const int led1 = 13;
const int led2 = 12;
//set trigger and echo pin
const int trigger = 11;
const int echo = 10;
long leddistance,
ledduration;
enum SWsensorDo {inittime,water, soap, water2,off}; // the states a single traffic light can be in
// the above line makes a variable data type "SWsensorDo" and assigns values 0, 1, 2, to water, soap, water2
SWsensorDo SWactivate; //create a variable sensorDO
const int timings[] = {1000,2000, 400, 15000, 3000};
unsigned long timeStart, timeElapsed ;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
digitalWrite(led1,LOW);
digitalWrite(led2,LOW);
SWactivate = inittime;
timeStart = millis();
measure_distance();
while(leddistance<=23)
person_flag;
if(person_flag)
measure_distance();
if(leddistance>23)
person_flag=false;
SWactivate = inittime; //start with the amber on
SWactivate = water;
OFF_All();
if(leddistance>23)
OFF_All();
switch (SWactivate) {
case inittime: {
digitalWrite(led2, LOW);
digitalWrite(led1, LOW);
//is it time for the next state?
timeElapsed = millis() - timeStart;
if (timeElapsed > timings[inittime]) {
//restart the timer and change the state
case water : {
//set the lights for this state
digitalWrite(led1, HIGH);
if (timeElapsed > timings[water]) {
SWactivate = soap;
case soap: {
digitalWrite(led2, HIGH);
if (timeElapsed > timings[soap]) {
//timeStart = millis();
SWactivate = water2;
case water2: {
if (timeElapsed > timings[water2]) {
SWactivate = off;
case off:
}//loop
void measure_distance()
digitalWrite(trigger,LOW);
delayMicroseconds(2);
digitalWrite(trigger,HIGH);
delayMicroseconds(15);
ledduration = pulseIn(echo, HIGH);
leddistance = (ledduration/2)/29;
delay(5);
void OFF_All()
