I am trying to make a project where two PIR sensors will be place at a distance of 1 feet. When movement occurs the first PIR sensors to catch the movement and second one two remain off at that time. The opposite will happen when the second one will catch at first.
Is there any way to do this with out a multiplexer ?
I have connected the input pins from the two sensors to digital pins. Until now they are working fine. Except during the count both remain active and they detect the motion together.
It would be great if you suggest me a tweak in code .
If I have to use multiplexer then can u please help me with the code and connection.
Thanks in Advance.
Here is the code:
[code]int ledPin = 13; // choose the pin for the LED A
int inputPinA = 2; // choose the input pin (for PIR sensor A)
int pirStateA = LOW; // we start, assuming no motion detected by A
int valA = 0; // variable for reading the pin status for A
int inputPinB = 3; // choose the input pin (for PIR sensor B)
int pirStateB = LOW; // we start, assuming no motion detected by B
int valB = 0; // variable for reading the pin status for B
int count = 0;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPinA, INPUT); // declare sensor as input
pinMode(inputPinB, INPUT); // declare sensor as input
OptimusPrime:
/// Program for sensor A///
valA = digitalRead(inputPinA); // read input value
if (valA == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH);
if (pirStateA == LOW) {
Serial.println("People Have Entered");
count ++;
Serial.println("Number of people:");
Serial.println(count);
// we have just turned on
// We only want to print on the output change, not state
pirStateA = HIGH;
else {
//digitalWrite(ledPin, LOW); // now led remain on
if (pirStateA == HIGH){
// we have just turned of
Serial.println(" A Sensor ended!");
pirStateA = LOW;
///Program for sensor B ///
valB = digitalRead(inputPinB); // read input value
if (valB == HIGH) { // check if the input is HIGH
if (pirStateB == LOW) {
Serial.println("People Left");
count -- ;
Serial.println("Number of people remained:");
pirStateB = HIGH;
else {
if (pirStateB == HIGH){
Serial.println(" B Sensor ended!");
pirStateB = LOW;
///Program Counter///
if (count <= 0)
{digitalWrite(ledPin, LOW);}
else{
[/code]
test7.ino (2.2 KB)
