I have two stepper motors with a roll around their shafts and a cloth. The two ends of the cloth are rolled on rolls. One acts as a supply roll and the other like a take up take. How do I synchronize the speeds of these motors using Arduino such that the cloth is not slacked or pulled?
kumbhrageri:
That's fine! The thing is the speed of both the motors will change as I roll or unroll
Can you have some device that detects the tension in the cloth and uses that to adjust the speed of the take-up motor.
This might be a situation where a simple DC motor would be better for the take-up roll as it could be driven so as to maintain sufficient tension and would then adjust its speed automatically. Choose a motor that won't be damaged by over-heating if it is stalled.
The speed of the process could then be set by the stepper motor on the feed-out roll.
Could look up 'dancer' or 'dancer tension control systems'.
The usual thing to note, as you probably already found out ... is that when a roll diameter gets smaller and smaller on one roller (because the material is coming off it), and the other roll diameter gets larger and larger...... then the dynamics gradually change. So this is when things need to be done to make everything work nicely.
Obviously, if the system is very slow, then maybe no problem. But if you want the system to operate quickly, and get things done as quick as possible, then this is where all these other techniques come in handy, like tensioning and tension-control.
Tensioners shouldn't be hard to find, it's a very common way of tensioning tapes and fabrics and paper sheets and lots of other things.
Have you tried Google already for such devices?
Very big windows maybe
But your point stands: no chance to suggest parts without knowing detailed specs. And when you have those specs, it should be pretty easy to narrow it down to some suitable parts by browsing manufacturer's web sites.
