typos in code examples
I've noticed some typos regarding the use of Engineering units in code examples, etc., on the Arduino page. I thought it might be good practice to avoid proliferating those if possible by setting a good example whenever something gets posted on the Arduino website.
one example is the use of 'S' for seconds, should be a lower case 's' instead.
I used to work in tech pubs, so this is something I'm very familiar with having read all the doc standards, and sometimes it's a bit of a curse because they jump out at me when I see them. =)
other common typos are forgetting to put a space between the number and the unit:
3.3V should be 3.3 V, etc.
also capitalization stuff:
MHz not Mhz (Hz is always capitalized)
kHz not Khz (the k is lower case)
us/ms not uS/mS for micro/milliseconds
mV/mA not mv/ma for millivolts/milliamps
etc.
anyway, just posting for what it's worth, hopefully this can be incorporated at some point going forward.
Planned, I'm sure, for the 3030 time-frame. Don't hold your breath. There are far more serious issues with the reference material that has not been addressed.
