U blox f9p safe ubx raw data
i want to save ubx raw data on a sd card with the help of an arduino. I have an ardusimple module which sends data. On the serial monitore I am receiviing NMEA data. I use this code an the serial monitor is on 9600 baud.
[#include](javascript:void(0):wink: <SoftwareSerial.h>
[#define](javascript:void(0):wink: PIN_RXD 3
[#define](javascript:void(0):wink: PIN_TXD 4
[#define](javascript:void(0):wink: GPS_BAUD 38400
// serial connection to the GPS device
SoftwareSerial gpsSerial(PIN_RXD, PIN_TXD);
gpsSerial.begin(GPS_BAUD);
// Output raw GPS data to the serial monitor
while (gpsSerial.available() > 0) {
Serial.write(gpsSerial.read());
Now i want to receiving UBX binary, so i changed the device setting to:
in the serial monitor i get data but only in ,,???????????,,
do I need to change the baud rate or is there a problem with the device settings?
What GPS are You using? F ex the NEO6-M uses 9600 baud.
Im using an ardusimple simplertk2b lite, which has a f9p from ublox. in the u center it has a 38400baud
Okey. I never used that one. A link to the datasheet would be positive.
Your report, receiving ????? smells baud rate mismatch.
https://www.ardusimple.com/product/simplertk2blite/https://www.ardusimple.com/product/simplertk2blite/
yes it could be
