U8g2 Display doesnt Work as it should
Hi, im new and I have a project in which I want to build a sonar, but I have a problem, the output values on the display, which are supposed to show the distance, change much too slowly and lag, but I don't understand why that is please help me im very frustrated.
Sry for my bad english :slight_smile:
#include "U8g2lib.h"
#define Echopin 13
#define Trigpin 12
#define SERVOPIN 10
#include "Servo.h"
#include "HCSR04.h"
#define Buzzer 9
// 1,3 Zoll SH1106
 U8G2_SH1106_128X64_NONAME_F_HW_I2C oled(U8G2_R0);
UltraSonicDistanceSensor Abstandssensor (Trigpin,Echopin);
Servo Servomotor;
byte Servowinkel = 0;
int Serv = 0;
unsigned long previousMillis = 0;//für den Timer
const long intervall = 30;//für den Timer
  oled.setBusClock(100000);
  oled.begin();
  oled.clearBuffer();
  Servomotor.attach(SERVOPIN);
  pinMode(Buzzer,OUTPUT);
  digitalWrite(Buzzer,0);
  Servomotor.write (0);
  //Zeichnen der Benutzeroberfläche OLED:
  oled.setDrawColor(1);// Farbe weiß
  oled.firstPage();
  do
   oled.drawRFrame(0, 0, 128, 64, 3); //Rahmen
   oled.setFont(u8g2_font_helvB12_tf); //12 px
   oled.drawStr(2,15,"Sonar:");
   oled.drawLine(3,18,51,18); //Unterschrift von "Sonar"
   //Radar:
   oled.drawCircle(65,62, 34, U8G2_DRAW_UPPER_RIGHT);//Großer Kreis Rechts
   oled.drawCircle(63,62,34,U8G2_DRAW_UPPER_LEFT); //Großer Kreis Links
   oled.drawCircle(65,62, 24, U8G2_DRAW_UPPER_RIGHT); //Mittlerer Kreis Rechts
   oled.drawCircle(63,62,24,U8G2_DRAW_UPPER_LEFT);//Mittlerer Kreis Links
    oled.drawCircle(65,62, 14, U8G2_DRAW_UPPER_RIGHT);//Kleiner Kreis Rechts
   oled.drawCircle(63,62,14,U8G2_DRAW_UPPER_LEFT);//Kleiner Kreis Rechts
   oled.drawLine(64,62,64,25);//Mittlere Linie
   oled.drawLine(64,62,36,36);//Linke Linie
   oled.drawLine(64,62,92,36);//Rechte Linie
   oled.drawFrame(79,3,46,15);//Rechteck cm anzeige
   //damit cm immer direkt eine Freizeile hinter der entfernung steht
  if((currentMillis-previousMillis)>= intervall){//delay
   int Abstand = Abstandssensor.measureDistanceCm();
   oled.setFont(u8g2_font_ncenB08_tr);
   if(Abstand<=99){
   if(Abstand<10){
   oled.drawStr(88,14,"cm");
   else{
   oled.drawStr(94,14,"cm");
   else{
   oled.drawStr(82,14,"no");
  // x Koordinaten Radar OLED Display Start: 31 Ende: 99
  // y Koordinaten Radar OLED Display Start: 25 Ende: 62
  for(int Serv= 0; Serv<= 165;Serv++) // Servomotor geht nur dreht nur bis 165 alles danach ist quasi wie delay
Servomotor.write(Serv);
delay(10);
if(Abstand<30){
oled.setCursor(82,14);
oled.print(Abstand);
Serial.print(Abstand);
for(int Serv=165; Serv>0;Serv--) //for schleife wird solange ausgeführt bis sie false ist dann geht es erst weiter
delay(10);
if(Abstand<30){
  while (oled.nextPage());
Have you tried 400000 ?
Please Auto-Format your code and re-post it. It is difficult to follow with such poor indentation.
The OLED will not be updated until this line is executed.
Before that line can be executed, your code executes 2x for-loops that repeat 165 times and delay 10ms in each loop.
So your display will only update once every 3~3.5 seconds.
Yes it changes nothing
#include "Servo.h"
#include "HCSR04.h"
#define Echopin 13
#define Trigpin 12
#define SERVOPIN 10
// 1,3 Zoll SH1106
U8G2_SH1106_128X64_NONAME_1_HW_I2C oled(U8G2_R0);
UltraSonicDistanceSensor Abstandssensor(Trigpin, Echopin);
Servo Servomotor;
int Serv = 0;
  oled.setBusClock(400000);
  oled.begin();
  oled.clearBuffer();
  Servomotor.write(0);
  oled.setDrawColor(1);  // Farbe weiß
  oled.firstPage();
  do {
    oled.drawStr(2, 15, "Sonar:");
    oled.drawLine(3, 18, 51, 18);  //Unterschrift von "Sonar"
    //Radar:
    oled.drawCircle(65, 62, 34, U8G2_DRAW_UPPER_RIGHT);  //Großer Kreis Rechts
    oled.drawCircle(63, 62, 34, U8G2_DRAW_UPPER_LEFT);   //Großer Kreis Links
    oled.drawCircle(65, 62, 24, U8G2_DRAW_UPPER_RIGHT);  //Mittlerer Kreis Rechts
    oled.drawCircle(63, 62, 24, U8G2_DRAW_UPPER_LEFT);   //Mittlerer Kreis Links
    oled.drawCircle(65, 62, 14, U8G2_DRAW_UPPER_RIGHT);  //Kleiner Kreis Rechts
    oled.drawCircle(63, 62, 14, U8G2_DRAW_UPPER_LEFT);   //Kleiner Kreis Rechts
    oled.drawLine(64, 62, 64, 25);  //Mittlere Linie
    oled.drawLine(64, 62, 36, 36);  //Linke Linie
    oled.drawLine(64, 62, 92, 36);  //Rechte Linie
    oled.drawFrame(79, 3, 46, 15);  //Rechteck cm anzeige
    for (int Serv = 0; Serv <= 165; Serv++)  // Servomotor geht nur dreht nur bis 165 alles danach ist quasi wie delay
      delay(10);
      if (Abstand < 30) {
        if (Abstand <= 99) {
          if (Abstand < 10) {
            oled.drawStr(88, 14, "cm");  //damit cm immer direkt eine Freizeile hinter der entfernung steht
            oled.drawStr(94, 14, "cm");
          oled.drawStr(82, 14, "no");
        oled.setCursor(82, 14);
    for (int Serv = 165; Serv > 0; Serv--)  //for schleife wird solange ausgeführt bis sie false ist dann geht es erst weiter
      delay(10);
      if (Abstand < 30) {
          if (Abstand < 10) {
Having read your code in more detail, I agree, increasing the i2c clock will make no difference.
The problem is the way you have structured your code.
Try this
#include "Servo.h"
#include "HCSR04.h"
#define Echopin 13
#define Trigpin 12
#define SERVOPIN 10
// 1,3 Zoll SH1106
Servo Servomotor;
int Serv = 0;
  oled.begin();
  oled.clearBuffer();
    //Radar:
    oled.sendBuffer();
      delay(10);
      if (Abstand < 30) {
          if (Abstand < 10) {
        oled.sendBuffer();
      delay(10);
      if (Abstand < 30) {
          if (Abstand < 10) {
        oled.sendBuffer();
There are other problems with your code.
For example:
      if (Abstand < 30) {
If a value is less than 30, it must also be less than 99, so why test it against 99?
