UART buffer size -- is it 63 or 64?
Theoretically, I know that UART buffer size is 64 which means, it can store up to 64 characters coming from INPUT BOX of Serial Monitor. The following sketch shows that I can catch only 63 characters coming from INPUT BOX implying that buffer size is 63. I would appreciate if someone clarifies the case.
  L1: byte n = Serial.available();
  if ( n != 64)    // works for n != 63
    goto L1;
  Serial.println(n);
void loop() {}
Why this is so important?
The right code should flush the buffer way before it overflowed.
It is important; because, I want to verify that the buffer size is indeed 64.
I understand that the buffer will be overflowed when more than 64 characters will be entered.
When I enter 63 characters (with No line ending option), the sketch works with if(n != 63) and the Serial Monitor shows 63.
When I enter 64 characters (with No line ending option), the sketch does not work with if(n != 64) and the Serial Monitor shows nothing.
You have the source at your fingertips.
Take a view into the Serial-libary to gain the knowledge.
@b707 actually implies that you should collect data when it becomes available; not wait till you have 64 bytes in the serial input buffer and then read them all.
Serial Input Basics - updated might be applicable.
byte buffer[64];
read 64 bytes from serial
Returns:
  true when 64 bytes are read, else false;
bool readSerial()
  static uint8_t idx = 0;
  if(Serial.available() >= 0)
    buffer[idx++] = Serial.read():
  if(idx == 64)
    idx = 0;
    return true;
  return false;
You call this repeatedly from loop()
  if(readSerial() == true)
    process the data
Note:
not tested but it should give you the idea.
Welcome to the forum
Sorry, but it is my policy never to examine code that uses goto
It is common that an n-byte circular buffer will be considered "full" when it contains n-1 bytes.
As the others have said, it's all Open Source - so you can take a look at the code if it's important to you ...
Added:
Your sketch works well; but, it does not answer to my query as you always clear the buffer by reading a character as it arrives. I want to read all the 64 characters once they are accumulated. (There are two typo mistakes in sketch of post #6 which I have corrected.)
if(Serial.available() > 0)
    buffer[idx++] = Serial.read();
Again, that query could be answered by looking at the Serial library source code.
It is, indeed, using a Ring Buffer:
Then you really don't need a circular buffer ...
Using goto statement, the OP observes visually that the program control is reverting to his designated label. The following equivalent codes do the same thing with a little bit of abstraction.
  while (Serial.available() != 63)
  for (int i = 0; i < 63; i++)
    Serial.print((char)Serial.read());
void loop() {}
This seems to be a bad programming idea for me
I know that :wink:
In my opinion it's the wrong approach; you should read when bytes arrive, not when your buffer is full.
So why do you want to do that?
What advantage does that bring?
It seems to me that it just adds overhead to no benefit? :thinking:
Thank you. This article actually contains the answer to my query of knowing that if the buffer size is 63 or 64. Now, I know that it's a circular buffer and the actual capacity is N-1 = 64-1 = 63.
Note that it's not necessarily the case that a Circular Buffer of length N can only hold N-1 entries - but that is a common implementation.
Again, if you really want to know for sure, then you need to check the source code.
You still to ignore the questions why you need to process a packet of 64 bytes at once.
I don't want to process 64 characters at once; rather, I want to know through experiment that the serial buffer has 64 locations to hold 64 characters.
Again, why not just look at the source code - no need to mess about with experiments which may or may not yield valid results.
:roll_eyes:
The HardwareSerial.h says that --
We're
// using a ring buffer (I think), in which head is the index of the location
// to which to write the next incoming character and tail is the index of the
// location from which to read.
#define SERIAL_RX_BUFFER_SIZE 64
#define SERIAL_TX_BUFFER_SIZE 64
Nowhere is told that the actual capacity is N-1 bytes. It is only the experiment through which the OP has discovered the fact which has been supported by post #8 @awneil.
