UART laser rangefinder help!
Evening all,
I have spent most of the day on this and I am not getting anywhere! I have a JRT laser range finder which uses a UART interface, the unit is a couple of years old but is essentially the same as this one China Customized 100m UART Output Laser Sensor For Distance Measurement Manufacturers, Suppliers - Factory Direct Wholesale - JRT.
According to the not particularly detailed instructions, I have 4 options, I can print "O" to the module to turn the laser on, "D" to initiate a single measurement, "C" for off and "S" for module status. The module is connected to an arduino device using the standard Tx/Rx pins, a 3v pin and a ground. I have managed to sent a serial command "O" to turn the laser on but I have not managed to get much further.
I am hoping (fingers crossed) that someone has managed to get past this point in the past and have a very simple code that will switch the laser on, take a measurement which can be displayed in the serial console and then switch the laser back off. I have tried every example code I can find and hammered google for a good couple of hours but I have not managed to find anything that works. Please help!
For any possible help, please show us the code that works to turn the unit on.
There are dozens of Arduinos and some have more that one serial port.
So which is it?
Which Arduino are you using and how is it wired?
Be aware that you cannot directly connect I/O pins on a 5V Arduino to a 3.3V sensor, as that can destroy both devices.
This post on the JRT sensor should be helpful.
