Looking at the message again, with some additional word-wrap
Error loading Python lib '/tmp/_MEIaEqtS1/libpython3.8.so.1.0':
dlopen: /lib/x86_64-linux-gnu/libm.so.6:
version `GLIBC_2.29' not found
(required by /tmp/_MEIaEqtS1/libpython3.8.so.1.0)
No surprise both files are there; you wouldn't get the error otherwise
- trying to load
libpython
- requires
libm, which is the basic math library, m
- which requires GLIBC_2.29
You said your Ubuntu 22.04 has GLIBC 2.29, maybe checked with
$ ldd --version
ldd (Ubuntu GLIBC 2.39-0ubuntu8.3) 2.39
(I have 2.39 with 22.04) You can verify the requirements for libm with
$ objdump -T /lib/x86_64-linux-gnu/libm.so.6 | grep -E '\.text.+GLIBC' | sed 's/.*GLIBC_\([.0-9]*\).*/\1/g' | sort -V | uniq -c
312 2.2.5
81 2.15
3 2.18
3 2.23
6 2.24
50 2.25
136 2.26
421 2.27
52 2.28
5 2.29
16 2.31
1 2.32
92 2.35
2 2.38
1 2.39
(My libm is actually in /usr/lib) This says that it has 312 dependencies on GLIBC 2.2.5, and one for the latest/current 2.39.
Is Python installed correctly on your system? Run python3 in another window, then run
$ lsof -p `pgrep python3`
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
python3 5519 kenb4 cwd DIR 259,2 4096 9961473 /home/kenb4
python3 5519 kenb4 rtd DIR 259,3 4096 2 /
python3 5519 kenb4 txt REG 259,3 8023232 5902618 /usr/bin/python3.12
python3 5519 kenb4 mem REG 259,3 5719296 5903151 /usr/lib/locale/locale-archive
python3 5519 kenb4 mem REG 259,3 344096 5924555 /usr/lib/x86_64-linux-gnu/libreadline.so.8.2
python3 5519 kenb4 mem REG 259,3 2125328 5910255 /usr/lib/x86_64-linux-gnu/libc.so.6
python3 5519 kenb4 mem REG 259,3 208328 5898314 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
python3 5519 kenb4 mem REG 259,3 170240 5903277 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
python3 5519 kenb4 mem REG 259,3 113000 5905701 /usr/lib/x86_64-linux-gnu/libz.so.1.3
python3 5519 kenb4 mem REG 259,3 952616 5910258 /usr/lib/x86_64-linux-gnu/libm.so.6
python3 5519 kenb4 mem REG 259,3 40640 8258224 /usr/lib/python3.12/lib-dynload/readline.cpython-312-x86_64-linux-gnu.so
python3 5519 kenb4 mem REG 259,3 27028 5910245 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
python3 5519 kenb4 mem REG 259,3 236616 5910252 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
python3 5519 kenb4 0u CHR 136,1 0t0 4 /dev/pts/1
python3 5519 kenb4 1u CHR 136,1 0t0 4 /dev/pts/1
python3 5519 kenb4 2u CHR 136,1 0t0 4 /dev/pts/1
You can see the libm is listed, so the GLIBC dependency is fulfilled.
What's suspicious is that your failing libpython is in /tmp: /tmp/_MEIaEqtS1/libpython3.8.so.1.0. That hints that it's using an alternate file system root of some kind. And there, the GLIBC is too old. What else is in /tmp/_MEIaEqtS1?
