UDP-Client schreiben
Hey Community, ich versuche einen UDP Client zu schreiben der sich einfach auf ein Socket in Visual Studio verbinden soll. Zurzeit arbeite ich mit dem Beispielsketch von der Library Ethernet2 (UDPSendReceiveString)
  UDPSendReceive.pde:
 This sketch receives UDP message strings, prints them to the serial port
 and sends an "acknowledge" string back to the sender
 A Processing sketch is included at the end of file that can be used to send
 and received messages for testing with a computer.
 created 21 Aug 2010
 by Michael Margolis
 This code is in the public domain.
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet2.h>
#include <EthernetUdp2.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "acknowledged";       // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  // start the Ethernet and UDP:
  Ethernet.begin(mac, ip);
  Udp.begin(localPort);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize)
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i = 0; i < 4; i++)
      Serial.print(remote[i], DEC);
      if (i < 3)
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    // read the packet into packetBufffer
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
    // send a reply, to the IP address and port that sent us the packet we received
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(ReplyBuffer);
    Udp.endPacket();
  delay(10);
  Processing sketch to run with this example
 // Processing UDP example to send and receive string data from Arduino
 // press any key to send the "Hello Arduino" message
 import hypermedia.net.*;
 UDP udp;  // define the UDP object
 udp = new UDP( this, 6000 );  // create a new datagram connection on port 6000
 //udp.log( true ); 		// <-- printout the connection activity
 udp.listen( true );           // and wait for incoming message
 void draw()
 void keyPressed() {
 String ip       = "192.168.1.177";	// the remote IP address
 int port        = 8888;		// the destination port
 udp.send("Hello World", ip, port );   // the message to send
 void receive( byte[] data ) { 			// <-- default handler
 //void receive( byte[] data, String ip, int port ) {	// <-- extended handler
 for(int i=0; i < data.length; i++)
 print(char(data[i]));
 println();
Nur wie ist es möglich das ganze zum laufen zu bekommen ohne zuerst eine Nachricht von jemanden zu bekommen?
Wenn Du als erster senden willst, mußt Du die IP und den Port wissen. Die müssen am Server dann fest sein, damit du ihn ansprechen kannst.
Gruß Tommy
Warum benutzt du die Ethernet2 ?
ElEspanol:
Habe ein EthernetShield 2
