Hi everyone, hope you're having a good day.
I am using an ESP32 as a client to send ADC data to a server on my PC.
Currently I am filling up a 2D buffer to send as a large packet (to maximise throughput):
When I receive the data on my PC the first byte is in the wrong order.
#include <WiFi.h>
#include <WiFiUdp.h>
/* WiFi network name and password */
//const char * ssid = "ABD";
//const char * pwd = "$S1mul4t0r$";
const char * ssid = "WiFi Guest_";
const char * pwd = "";
// IP address to send UDP data to.
// it can be ip address of the server or
// a network broadcast address
// here is broadcast address
const char * udpAddress = "172.24.29.139";
const int udpPort = 1234;
#define numOfCh 8
#define numOfTs 32
unsigned long adcSample = 0b11111111111111111111111111111110;
//uint8_t adcSample = 0b11111110;
long buff[numOfCh][numOfTs];
int channel = 0;
int timestep = 0;
//create UDP instance
WiFiUDP udp;
//Connect to the WiFi network
WiFi.begin(ssid, pwd);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
//This initializes udp and transfer buffer
udp.begin(udpPort);
buff[channel][timestep] = adcSample;
channel = (channel + 1) % numOfCh;
if (channel == 0)
timestep = (timestep + 1) % numOfTs;
if (timestep == 0)
udp.beginPacket(udpAddress, udpPort);
udp.write((uint8_t*)buff, sizeof(buff));
udp.endPacket();
//for(int i =0; i<numOfCh;i++){
// for(int j = 0; j<numOfTs; j++){
// Serial.print(buff[i][j],BIN);
// Serial.print(" ");
// Serial.println();
// Serial.println("-------------");
On the receiving end I am getting the packets coming in as: b'\xfe\xff\xff\xff\xfe\xff\xff\xff\xfe\xff\xff\xff\
which is equivalent to:
11111110111111111111111111111111111111101111111111111111111111111111111
But I expect to receive:
b'\xff\xff\xff\xfe\xff\xff\xff\xfe\xff\xff\xff\xfe\
equivalent to:
11111111111111111111111111111110111111111111111111111111111111111111110
Hopefully that's clear. Any ideas on how to fix this would be amazing!
P.S I have tried using pointers but WiFiUDP didn't want to print them.
