just hit this issue and I'm not sure whether this is expected or not. when performing calculation with unsigned values (subtracting greater value from smaller), Arduino Returns max uint value plus negative result. That would be fine, as we are working with unsigned ints. Doing the same with signed INTs causes problem not appearing, of course.
This happens when running this program on MEGA32u4 and does not happen when running the same sketch on ESP8266. Didn't try MEGA328 though
I hit this problem when doing a fish feeder with millis() condition if(abs(millis()-lastFeed)>feedFreq){ ... }. when the UINT rolls over, the condition is true immediately after rollover because I get a number close to UINT_MAX. I know I'm using UINT when I'm supposed to use ULONG, but this is only for testing the rollover.
can anybody explain what is going on here and why the behaviour of MEGA is different than on ESP8266?
No, because you f**ked up. You are NEVER supposed to replace code in the original post, after you get replies telling you that there are problems with it.
Using abs() with an unsigned int argument is just plain stupid. Why do you feel the need to do that?
Try this
Store b-a in signed type i.e. int and serial print int value. Could be problem with Serial.print() on 16bit vs 32bit(esp8266). On one its overflowing on the other one not. Cant explain have no time to think about that but pretty interesting problem.
surepic:
Try this
finally some comment that makes sense. only took few posts, thanks it might be worth looking at sources, but no idea what to look for
now I've found another weird thing. I switched the machine ( -1 was returned by sketch compiled on a Mac) to a Windows one and now I'm getting this from the ESP8266
ESP8266 output
a-b=1
b-a=4294967295
this time it calculates correctly but somehow the result from math operation on two unsigned INTs is a LONG. Sketch is still the same (previously modified to prevent PaulS' distraction):
unsigned int a=4;
unsigned int b=3;
void setup(){
delay(5000);
void loop(){
Serial.println("==========");
Serial.print("a-b=");
Serial.println(a-b);
Serial.print("b-a=");
Serial.println(b-a);
delay(2000);
maybe sir PaulS has something to say here now? or have you found some wrong syntax or String class?
If you are now getting 65536 on the Uno and 4294967295 on the ESP, then you are getting correct results. The size of an int, or unsigned int, on the two platforms is different, so the results will be different. This is to be expected.
int isn't a fixed size. Yes, on a Uno and Mega it's 2 bytes but on a ESP8266 it's 4-bytes.
The results which roll over are the ones I would expect. Because uint - uint should happen in uint. Why the Mac compiler does not and threats it as an signed, I don't know.
surepic:
Try this
right, here it is. if I save the result into a signed integer, it is calculated like I operated on signed INTs.
unsigned int a=4;
unsigned int b=3;
signed int resultA,resultB;
void setup(){
delay(5000);
void loop(){
resultA=a-b; // this would be 1
resultB=b-a; // this would be -1
Serial.print("ResultA=");
Serial.println(resultA);
Serial.print("ResultB=");
Serial.println(resultB);
delay(2000);
regarding the original problem where it returned -1 from subtraction of two unsigned values, I'll probably "reinstall" complete IDE on the Mac and test again
PaulS:
septillion:
Could this be avoided by delcaring the variable as uint16_t instead of unsigned int?
