uint8_t * uint8_t oddity
I've got a problem with a product of 2 uint8_t variables.
If I do this:
uint8_t val = 255;
uint8_t sat = 255;
uint16_t output = val*sat/120;
the result of output is 'strange' at best, definitely too big. It should be around 540 something, but ends up close to 0xFFFF. Using brackets around (val*sat) to reduce rounding errors is futile as well.
Changing the code to this helps, WHY ?
uint8_t val = 255;
uint8_t sat = 255;
uint16_t product = val*sat;
uint16_t output = product/120;
The actual code is this:
void
set_led_hsv (uint8_t led, uint16_t hue, uint8_t sat, uint8_t val)
  /* BETA */
  /* finally thrown out all of the float stuff and replaced with uint16_t
   * hue: 0-->360 (hue, color)
   * sat: 0-->255 (saturation)
   * val: 0-->255 (value, brightness)
  hue = hue % 360;
  uint8_t sector = hue / 60;
  uint8_t rel_pos = hue - (sector*60);
  uint16_t const mmd = 255*255; /* maximum modulation depth */
  uint16_t top = val*255;
  uint16_t bottom = val*(255-sat); /* (val*255) - (val*255)*(sat/255) */
  uint16_t mod_depth = val*sat;
  uint16_t slope = mod_depth/120; /* dy/dx = (top-bottom)/(2*60) */
  uint16_t a = bottom + slope*rel_pos;
  uint16_t b = bottom + mod_depth/2 + slope*rel_pos;
  uint16_t c = top - slope*rel_pos;
  uint16_t d = top - mod_depth/2 - slope*rel_pos;
  Serial.print("hue: ");
  Serial.println(hue,DEC);
  Serial.print("sat: ");
  Serial.println(sat,DEC);
  Serial.print("val: ");
  Serial.println(val,DEC);
  Serial.print("sector: ");
  Serial.println(sector,DEC);
  Serial.print("rel_pos: ");
  Serial.println(rel_pos,DEC);
  Serial.print("top: ");
  Serial.println(top,DEC);
  Serial.print("bottom: ");
  Serial.println(bottom,DEC);
  Serial.print("slope: ");
  Serial.println(slope,DEC);
  Serial.print("a: ");
  Serial.println(a,DEC);
  Serial.print("b: ");
  Serial.println(b,DEC);
  Serial.print("c: ");
  Serial.println(c,DEC);
  Serial.print("d: ");
  Serial.println(d,DEC);
  uint16_t R, G, B;
  if (sector == 0)
      R = c;
      G = a;
      B = 0;
  else if (sector == 1)
      R = d;
      G = b;
      B = 0;
  else if (sector == 2)
      R = 0;
      G = c;
      B = a;
  else if (sector == 3)
      R = 0;
      G = d;
      B = b;
  else if (sector == 4)
      R = a;
      G = 0;
      B = c;
      R = b;
      G = 0;
      B = d;
  uint16_t scale_factor = mmd / __max_brightness;
  R = (uint8_t) (R / scale_factor);
  G = (uint8_t) (G / scale_factor);
  B = (uint8_t) (B / scale_factor);
  set_led_rgb (led, R, G, B);
This function is used to convert HSV color space to RGB.
The val and sat variables are uint8_t, so a uint8_t-sized space is used to hold the result of val*sat, which results in an overflow.
You should be able to use an explicit cast, rather than an intermediate variable:
uint16_t output = (uint16_t)(val*sat)/120;
Just to be safe, I'd cast both terms:uint16_t output = (uint16_t)val * (uint16_t)sat / 120;When type conversions are subtle, I think it makes the program easier to understand if you are explicit about what you want to do.
Regards,
-Mike
So basically use the good old "never assume anything" rule.
Thanks.
Edit: the explicit cast works :wink:
