raj412
February 13, 2017, 7:20am
1
ultra sonic sensor always showing 0.
can anyone help me to correct this
#define trigPin 13
#define echoPin 12
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(11, OUTPUT);
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Serial.print("distance is ");
Serial.print(distance);
Serial.println(" cm");
davidrh
February 13, 2017, 7:26am
2
Post a drawing or photo of how you have wired your sensor up. Is it an SR04 type sensor?
raj412
February 13, 2017, 7:29am
3
davidrh:
sro4
trigger pin to 13
echo pin to 12
vcc to 5v (3.3v also showing 0)
raj412:
sro4
trigger pin to 13
echo pin to 12
Welcome to the forum.
What about the gnd terminal of the sensor, and you need to post a circuit diagram, not a description.
Can you tell us your electronics, programming, Arduino, hardware experience?
Thanks.. Tom...
raj412
February 13, 2017, 7:52am
5
i followed the same connections as shown in below attached figure
