Hi, i'm using a D1 mini board with a 1.8 inch TFT SPI LCD and a ultrasonic sensor HC-sr04
My project is about a weather station so i also have "WundergroundClient and TimeClient librarys
Here is my code(simplified):
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include <Adafruit_ST7735.h>
#include <Adafruit_GFX.h>
#include <SPI.h>
#include "WundergroundClient.h"
#include "TimeClient.h"
#include <Ultrasonic.h>
#define TRIGGER_PIN D6
#define ECHO_PIN D2
#define cs D8
#define dc D3
#define rst D4
// Color definitions
#define BLACK 0x0000
//const char* ssid = "G3orG3"; // SSID of local network
//const char* password = "xxxx"; // Password on network
// TimeClient settings
const float UTC_OFFSET = 3;
// Wunderground Settings
const boolean IS_METRIC = true;
const String WUNDERGRROUND_API_KEY = "xxx";
const String WUNDERGRROUND_LANGUAGE = "RO";
const String WUNDERGROUND_COUNTRY = "RO";
const String WUNDERGROUND_CITY = "xxxx";
TimeClient timeClient(UTC_OFFSET);
// Set to false, if you prefere imperial/inches, Fahrenheit
WundergroundClient wunderground(IS_METRIC);
Ultrasonic ultrasonic(TRIGGER_PIN, ECHO_PIN); // (Trig PIN,Echo PIN)
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst); //initialize LCD
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
tft.setRotation(3);
tft.fillScreen(BLACK);
WiFi.begin(ssid, password);
Serial.println("Connected");
Serial.println(ultrasonic.Ranging(CM));
In the serial output i got the connected msg from the setup and then only the number 51 as the result ultrasonic sensor
I also tried using NewPing library
I also tried to measure the distance using this:
digitalWrite(TRIGGER_PIN, LOW);
delayMicroseconds(2);
// Sets the TRIGGER_PIN on HIGH state for 10 micro seconds
digitalWrite(TRIGGER_PIN, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
int duration = pulseIn(ECHO_PIN, HIGH);
// Calculating the distance
int dist = (duration * 0.034) / 2;
Serial.println(dist);
but still no luck !
