Yeah, I tried to post the data from the sensor into google spreadsheets.
The code for ESP8266 was:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include "HTTPSRedirect.h"
//Ultrasonic sensor
#define Trig_pin 2
#define Echo_pin 3
#define MAX_DISTANCE 300
// Enter network credentials:
const char* ssid = "";
const char* password = "";
// Enter Google Script Deployment ID: CHANGE IF YOU CREATED NEW SPREADSHEET AND NEW DEPLOYMENT
const char *GScriptId = "AKfycbwtPs0ayulB02P2t3gbKtn_cZ1cBzy_khCVCTH5oTy8ByvmMLMjh72JNVCsIF0EDLtF-A";
// Enter command (insert_row or append_row) and your Google Sheets sheet name (default is Sheet1):
String payload_base = "{"command": "insert_row", "sheet_name": "Sheet1", "values": ";
String payload = "";
// Google Sheets setup (do not edit)
const char* host = "script.google.com";
const int httpsPort = 443;
const char* fingerprint = "";
String url = String("/macros/s/") + GScriptId + "/exec";
HTTPSRedirect* client = nullptr;
pinMode(Trig_pin, OUTPUT);
pinMode(Echo_pin, INPUT);
digitalWrite(Trig_pin, LOW);
delay(10);
Serial.println('\n');
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.print(ssid); Serial.println(" ...");
Serial.print(".");
Serial.println("Connection established!");
Serial.print("IP address:\t");
// Use HTTPSRedirect class to create a new TLS connection
client = new HTTPSRedirect(httpsPort);
client->setInsecure();
client->setPrintResponseBody(true);
client->setContentTypeHeader("application/json");
Serial.println(host);
// Try to connect for a maximum of 5 times
bool flag = false;
for (int i=0; i<5; i++){
int retval = client->connect(host, httpsPort);
if (retval == 1){
flag = true;
Serial.println("Connected");
Serial.println("Connection failed. Retrying...");
if (!flag){
Serial.print("Could not connect to server: ");
return;
delete client; // delete HTTPSRedirect object
client = nullptr; // delete HTTPSRedirect object
long duration;
long distance;
int percentage;
digitalWrite(Trig_pin, HIGH);
delayMicroseconds(11);
duration = pulseIn(Echo_pin, HIGH);
distance = duration * 0.034/2;
percentage = map(distance, 0, 25, 0, 100);
if(percentage < 0) {
percentage = 0;
else if(percentage > 100) {
percentage = 100;
Serial.print("Percentage: ");
Serial.print(percentage);
Serial.print("% Distance: ");
Serial.print(distance);
Serial.print(" cm");
static bool flag = false;
if (!flag){
flag = true;
if (client != nullptr){
if (!client->connected()){
else{
Serial.println("Error creating client object!");
// Create json object string to send to Google Sheets
payload = payload_base + """ + distance + "," + percentage + ""}";
// Publish data to Google Sheets
Serial.println("Publishing data...");
Serial.println(payload);
if(client->POST(url, host, payload)){
// do stuff here if publish was successful
else{
// do stuff here if publish was not successful
Serial.println("Error while connecting");
// a delay of several seconds is required before publishing again
delay(5000);
