Ultrasonic Traffic-Light
I've been having some trouble with this "Ultrasonic Traffic-Light" and can't figure out why. I've browsed through forums, but can't find any that helps so decided to ask by a forum myself.
const int trig = 3;
const int echo = 4;
int stop = 0;
int slow = 1;
int go= 2;
long duration;
int distance;
  pinMode(stop, OUTPUT);
  pinMode(slow, OUTPUT);
  pinMode(go, OUTPUT);
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
  digitalWrite(trig, LOW);
  delay(10);
  digitalWrite(trig, HIGH);
  delay(10);
  duration = pulseIn(echo, HIGH);
  distance = duration*0.034/2;
  Serial.print("DISTANCE: ");
  Serial.println(distance);
  if(distance > 105){
    digitalWrite(go, HIGH);
    digitalWrite(stop, LOW);
  else(digitalWrite(stop, HIGH)); {
I just can get the red led (stop) to turn of when the green led(go) is on. The green led works as intended, it's just the red one that I'm having trouble with. Any help is appreciated.
Please post schematics. A wiring mistake can never be handle by the code.
Try with
if(distance > 105){
    digitalWrite(go, LOW);
    digitalWrite(stop, HIGH);
You could use functions to make the code more readable and an enum to describe the state of the system. Something like
const byte trigPin = 3;
const byte echoPin = 4;
const byte redPin = 5;
const byte yellowPin = 6;
const byte greenPin = 7;
const float goThreshold = 105.0;
const float slowThreshold = 50.0;
enum State { STOP, SLOW, GO };
State state = STOP;
float distance() {
  long duration;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH, 20000);
  return duration * 0.034 / 2.0;
void setLights() {
  digitalWrite(redPin, (state == STOP) ? HIGH : LOW);
  digitalWrite(yellowPin, (state == SLOW) ? HIGH : LOW);
  digitalWrite(greenPin, (state == GO) ? HIGH : LOW);
  pinMode(redPin, OUTPUT);
  pinMode(yellowPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  setLights();
  float dist = distance();
  State newState;
  if (dist > goThreshold) {
    newState = GO;
  } else if (dist > slowThreshold) {
    newState = SLOW;
    newState = STOP;
  if (newState != state) {
    state = newState;
    setLights();
  delay(50);
Hi, @hhhmsroboticsclub
Welcome to the forum.
What Arduino controller are you using?
Have you looked a NewPing library to do your range finding?
https://docs.arduino.cc/libraries/newping/
Tom.... :smiley: :+1: :coffee: :australia:
It worked, but I would've liked if you could label your stuff, similar to what you recommended. I say this because I would've liked to figure out what you did differently. Otherwise, thanks so much for your help!
Compare your code with @J-M-L 's and you'll notice what he did differently.
At least that's what I do, and it works for me.
I add:
To see if it helps you, I'm leaving you the code of @J-M-L commented by Copilot
// Define ultrasonic sensor pins
const byte trigPin = 3;     // Trigger pin for the ultrasonic sensor
const byte echoPin = 4;     // Echo pin for the ultrasonic sensor
// Define LED pins for traffic light simulation
const byte redPin = 5;      // Red LED pin (STOP)
const byte yellowPin = 6;   // Yellow LED pin (SLOW)
const byte greenPin = 7;    // Green LED pin (GO)
// Define distance thresholds in centimeters
const float goThreshold = 105.0;    // Distance above which the light turns green
const float slowThreshold = 50.0;   // Distance above which the light turns yellow
// Define traffic light states
State state = STOP;         // Initial state is STOP
// Function to measure distance using the ultrasonic sensor
float distance() {
  long duration;
  // Send a 10µs pulse to trigger the sensor
  // Measure the time it takes for the echo to return (timeout after 20ms)
  // Convert duration to distance in centimeters
// Function to update LED states based on current traffic state
void setLights() {
  digitalWrite(redPin, (state == STOP) ? HIGH : LOW);     // Turn on red LED if STOP
  digitalWrite(yellowPin, (state == SLOW) ? HIGH : LOW);  // Turn on yellow LED if SLOW
  digitalWrite(greenPin, (state == GO) ? HIGH : LOW);     // Turn on green LED if GO
// Arduino setup function (runs once at startup)
  // Set LED pins as outputs
  // Set ultrasonic sensor pins
  // Initialize LEDs based on initial state
  setLights();
// Arduino loop function (runs repeatedly)
  float dist = distance();   // Measure current distance
  State newState;
  // Determine traffic light state based on distance
    newState = GO;
    newState = SLOW;
    newState = STOP;
  // Update state and LEDs only if the state has changed
    state = newState;
    setLights();
  delay(50);  // Small delay to reduce flickering and CPU load
cool thanks! :smiley:
Curious to understand why this is solved by post 5…
Did you end up rewriting your code with that library ?
Can you explain what you don’t understand in my code ?
My bad, I accidentally clicked solution on the wrong one. Your's did work and I appreciate your help! (:smile:
