Today I spent hours chasing a bug which in the end turned out to have a simple solution (the usual story ). Having found it, I've reduced the code to a fraction of what it was, to show the problem. It's all to do with defining (not declaring) an unnamed struct in a header file.
So, in 'header.h' I had something like this:
struct {
 int value;
} definedInHeader;
Now, I know that's not good, the struct should be declared in the header and defined elsewhere. I had copied the struct code from someone else's cpp file (that didn't use a header) and moved it into a header carelessly. That header was then #included in two different .cpp files. The result was very strange things happening to the values of the contents of my struct.
Here's my full header for the simplified code:
// header1.h
#ifndef _HEADER1_h
#define _HEADER1_h
struct {
 int value;
} definedInHeader;
void incrementIt();
#endif
Here's my simplified .cpp file:
#include "header1.h"
void incrementIt() {
 definedInHeader.value += 1;
and here's my main .ino file:
 delay(100);
 definedInHeader.value = 2;
 incrementIt();
 Serial.println(definedInHeader.value);
which (of course) just prints '2' continuosly, rather than incrementing the value.
So, my question is, why doesn't the linker tell me that I have multiple defintions? If I had done this instead, and named the struct:
struct myStruct {
 int value;
} definedInHeader;
then the linker correctly tells me I have "multiple definition of `definedInHeader'"
Is this normal in C / C++ or just a bug in the linker?
