Hello everyone,
I'm currently working on an OBD project where I aim to establish communication using the MCP2515 CAN bus controller and the MCP2551 CAN transceiver. In the initial stages of this project, I successfully used the MCP2515 CAN bus module (with a TJA1050) and got it working. Later, I replaced the transceiver side with standalone MCP2515 and MCP2551 components and got it working as well.
Here's the challenge I'm facing: I've created my own circuits and made that work while being connected to the CAN bus module. However, when I try to connect the two "standalone" parts to each other, they don't seem to communicate. The error message I'm encountering is "Error sending message." I've tried numerous troubleshooting steps, but I'm still unable to figure out why they won't establish communication. I've notice that the Arduino uno provides 5V while the arduino nano provides 4.8V. I don't know if that really makes any difference.
I'll be attaching pictures of my circuit and the code I've been using for reference. Any insights or ideas would be highly appreciated!
Some information about the circuit:
The capacitors at OSC1, OSC2, RXD are 27pF
The voltage capacitors are 10uF (electrolytic) and 100nF (ceramic)
The Reset resistor is 10k Ohm
The RS resistor is 4.7k Ohm
The CANH/L resistor is 120 Ohm and the capacitor is 100pF
// CAN Send Example
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN0(10); // Set CS to pin 10
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
else Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
byte data[8] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07};
byte data2[8] = {0x08, 0x07, 0x06, 0x05, 0x04, 0x03, 0x02, 0x01};
// send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
byte sndStat = CAN0.sendMsgBuf(0x400, 0, 8, data);
byte sndStat2 = CAN0.sendMsgBuf(0x100, 0, 8, data2);
if(sndStat == CAN_OK){
Serial.println("Message Sent Successfully!");
Serial.println("Error Sending Message...");
delay(100); // send data per 100ms
END FILE
// CAN Receive Example
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128]; // Array to store serial string
#define CAN0_INT 2 // Set INT to pin 2
if (CAN0.begin(MCP_ANY, CAN_250KBPS, MCP_16MHZ) == CAN_OK)
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
Serial.println("MCP2515 Library Receive Example...");
if (!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if ((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if ((rxId & 0x40000000) == 0x40000000) { // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for (byte i = 0; i < len; i++) {
sprintf(msgString, " 0x%.2X", rxBuf[i]);
END FILE
