Hi everyone, i am relatively new to the arduino IDE. I have been an embedded programmer for more than 20 years but never really used systematically arduinos but instead i (almost) always designed my own custom boards.
I downloaded the latest Arduino IDE 2.2.1 in my linux box (linux mint 20.x). The IDE worked fine. I tried the pre-compiled and appimage options and both worked w/o any abnormal behavior.
I ordered two Arduino Nano ESP32 boards from TME and received them today.
I plugged in the type-c cable and noticed that after some short blinking of the leds, the rgb was blinking every 1 sec in the following sequence R->G->B->R...
I got a message in the IDE that the "Arduino ESP32 Boards [v 2.0.13]" core has to be installed. I clicked on Yes button and noticed in the output tab the progress of installed dependencies as follows:
Downloading packages
esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0
esp32:xtensa-esp-elf-gdb@11.2_20220823
esp32:openocd-esp32@v0.11.0-esp32-20221026
esp32:esptool_py@4.5.1
esp32:mkspiffs@0.2.3
esp32:mklittlefs@3.0.0-gnu12-dc7f933
arduino:dfu-util@0.11.0-arduino5
arduino:esp32@2.0.13
Installing esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0
Configuring tool.
esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0 installed
Installing esp32:xtensa-esp-elf-gdb@11.2_20220823
Configuring tool.
esp32:xtensa-esp-elf-gdb@11.2_20220823 installed
Installing esp32:openocd-esp32@v0.11.0-esp32-20221026
Configuring tool.
esp32:openocd-esp32@v0.11.0-esp32-20221026 installed
Installing esp32:esptool_py@4.5.1
Configuring tool.
esp32:esptool_py@4.5.1 installed
Installing esp32:mkspiffs@0.2.3
Configuring tool.
esp32:mkspiffs@0.2.3 installed
Installing esp32:mklittlefs@3.0.0-gnu12-dc7f933
Configuring tool.
esp32:mklittlefs@3.0.0-gnu12-dc7f933 installed
Installing arduino:dfu-util@0.11.0-arduino5
Configuring tool.
arduino:dfu-util@0.11.0-arduino5 installed
Installing platform arduino:esp32@2.0.13
Configuring platform.
Platform arduino:esp32@2.0.13 installed
No abnormal behavior was observed.
I then clicked on the tick button (compile) and i got the following in the output tab:
Traceback (most recent call last):
File "/home/manos/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool.py", line 31, in <module>
import esptool
File "/home/manos/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 41, in <module>
from esptool.cmds import (
File "/home/manos/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/cmds.py", line 14, in <module>
from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
File "/home/manos/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/bin_image.py", line 14, in <module>
from .loader import ESPLoader
File "/home/manos/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 30, in <module>
import serial
ModuleNotFoundError: No module named 'serial'
exit status 1
Compilation error: exit status 1
I know that this board can run micro-python but i was surprised to see these messages without having done anything to the board. Then i tried a second and i got the same behavior.
So i was not able to compile or upload an empty sketch's code to the board.
I googled and found the "Reinstalling the C++ Arduino Bootloader" in this page: https://dronebotworkshop.com/nano-esp32/ and tried short-circuiting B1 to GND, then pressing/releasing the RST button on the board and finally removing the short between B1 & GND. I got the expected purple-like led indicating that the board is in bootloader mode. I did exactly what the page says:
- Selected the Arduino board (Menu Tools->Board) - It was already selected as "Arduino Nano ESP32".
- Selected the programmer by using menu Tools->Programmer - "Esptool" was already selected.
- Tried to upload the bootloader & sketch code by using menu Sketch->Upload using programmer.
I ended up getting the exact same error message no matter what i did. I re-did the entire process from scratch a few times and always got the same error message.
I even tried a second usb-c cable but i got the same results.
I have no idea what is going on.
Any help will be highly appreciated.
Regards to all.
Manos
