I am trying to read the data form RS232 to TTL converter using PCAN. I have connected my ESP32's SERIAL1 pins to RS232 to TTL Converter's Rx & Tx pins. The module is recognized on the PCAN View but I am unable to receive the data. I am using the example code of CAN library available on Arduino IDE.
The Example Code:
#include <CAN.h>
while (!Serial);
Serial.println("CAN Sender");
// start the CAN bus at 250 kbps
if (!CAN.begin(250E3)) {
Serial.println("Starting CAN failed!");
while (1);
// send packet: id is 11 bits, packet can contain up to 8 bytes of data
Serial.print("Sending packet ... ");
CAN.beginPacket(0x12);
CAN.write('h');
CAN.write('e');
CAN.write('l');
CAN.write('l');
CAN.write('o');
CAN.endPacket();
Serial.println("done");
// send extended packet: id is 29 bits, packet can contain up to 8 bytes of data
Serial.print("Sending extended packet ... ");
CAN.beginExtendedPacket(0xabcdef);
CAN.write('w');
CAN.write('o');
CAN.write('r');
CAN.write('l');
CAN.write('d');
CAN.endPacket();
Lets sort this out, post an annotated schematic showing exactly how this is wired. Be sure to show all connections, power, ground, power sources. Also important include links to technical information on each of the hardware devices. What you are telling us is working as expected, it won't do much of anything.
You can't use those if you use serial monitor. Use pins GPIO16/17 for your converter Serial2.begin(9600, SERIAL_8N1, 16, 17);
But first answer to posts#2 and 3.
Check that you have connected UART2 (Serial2) Port of ESP32 with TTL <-----> RS232 Converter as per Fig-1 and you have included this code in your sketch: Serial2.begin(9600).
initially try a loopback test on the TTL-RS232 module, e.g. connect 9-pin D_type connector pins 2 Tx to 3 Rx (pin 5 is GND)
simple program to test loopback
// ESP32 Serial1 test - for loopback test connect pins RXD1 and TXD1
#define RXD1 16 // can map Serial1 and Serial2 to many ESP32 GPIO pins
#define TXD1 17 // check pin usage https://randomnerdtutorials.com/esp32-pinout-reference-gpios/
// for RS232 shield connect
// ESP32 RXD1 to TTL/RS232 Rx
// ESP32 TXD1 to TTL/RS232 Tx
// connect GND pins together and VCC to 3.3V on ESP32 5V on UNO ect
// for loopback test connect 9-pin D_type connector pins 2 Tx to 3 Rx (pin 5 is GND)
// initialize both serial ports:
Serial1.begin(115200, SERIAL_8N1, RXD1, TXD1);
Serial.printf("\n\nESP32 serial1 test RXD1 pin %d TXD1 pin %d\n", RXD1, TXD1);
Serial.printf(" loopback test connect pin %d to pin %d\n", RXD1, TXD1);
Serial.printf("RS232: ESP32 pin %d RXD1 to TTL/RS232 Rx and pin %d TXD1 to TTL/RS232 Tx\n", RXD1, TXD1);
Serial.printf("RS232 - loopback connect 9-pin D-type pin 2 Tx to pin 3 Rx\n");
// read from Serial1, send to Serial
if (Serial1.available()) {
int inByte = Serial1.read();
Serial.write(inByte);
// read from Serial, send to Serial1
if (Serial.available()) {
int inByte = Serial.read();
//Serial.write(inByte); // local echo if required
Serial1.write(inByte);
you can map ESP32 Serial1 and Serial2 to the majority of GPIO pins whatever is convenient, e.g. Serial2 to pins 18 and 19
#define RXD2 18
#define TXD2 19
// Note the format for setting a serial port is as follows: Serial2.begin(baud-rate, protocol, RX pin, TX pin);
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
