Unable to Update Firmware on Arduino Nano 33 iot
Hello,
This my first Arduino Nano 33 iot I am trying to connect it to Bluetooth or WiFi both through iot cloud and Example sketches in IDE. I am using the Latest version of IDE.
My firmware appears to be missing or not updated after about 5 minutes I get a message saying we were unable to update firmware from iot.
I also tried using IDE 1 to update firmware but it gives me error saying Firmware Updater code not found. And the code example code from wifiNina/tools/Firmware update doesn't work it complaints about an library being not found.
I have also tried IDE 2 and it just says failed to update firmware after about 5 minutes.
I have also noticed when I try to update the firmware, the Arduino keeps disconnecting and reconnecting every 5-10 seconds.
I have used 3 different machines 2 windows and 1 macbook the problem still exist.
Please help !!!!
thank you
@arduinosupport Please help !!!
@asharma36
sometimes these issues happen when you forget to close the Serial Monitor in the IDE or have the Serial connection open towards the board.
Using IDE 2.1 is advised because the Firmware Upload Tool used automatically gets newer versions of the firmware and tools required.
Please read through the page linked by @Juraj and let us know if it worked out
u.
Hello,
I tried this method both in IDE 1 where it says Firmware updated sketch not found.. the example sketch from WiFiNina/tools/Firmware updater does not work.
In IDE 2 it just says firmware update failed.
Hi @asharma36. Which operating system are you using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
I am using windows 10. I do have a MacBook if that makes it easier.
When I try to update using IDE it automatically connects and disconnects every 2-3 seconds and eventually the update just fails.
I have tried using different cable, different computer and changing ports but i still have the same issue.
@ubidefeo @ptillisch I Also just installed IDE 1.8.9 and tired to update the firmware by following the tutorial but when I upload the the serial monitor says "Unable to communicate with ESP 32 Boot ROM" and I also tried uploading firmware check it says unanble to communicate with wifi module.
did you upload the FirmwareUpdater sketch?
Windows is fine. I'm going to ask you to start Arduino from the terminal and then gather the output that is printed there during the firmware update process.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  5. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting.
  9. Attempt a firmware update using Arduino IDE, just as you did before.
  10. Wait for the update process to fail.
  11. Switch back to the PowerShell window.
  12. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  13. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  14. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  15. Open a forum reply here by clicking the Reply button.
  16. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  17. Press Ctrl+V.
    This will paste the output into the code block.
  18. Move the cursor outside of the code block markup before you add any additional text to your reply.
  19. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
@ptillisch @ubidefeo
hey, sorry I wasnt able to try it earlier but i get these errors i think i does not have the folder you mentioned.
It looks like you uninstalled Arduino IDE 2.x. Please reinstall it and then perform the instructions again. The Arduino IDE 2.x download links are listed here:
You can have Arduino IDE 1.8.9 and Arduino IDE 2.x installed at the same time on your computer so there is no need for you to uninstall Arduino IDE 1.8.9 before installing Arduino IDE 2.x if for some reason you want to continue to have the option of using Arduino IDE 1.8.9 in addition to the modern version of the IDE.
@ptillisch
I have IDE 2 installed and it runs as you can see here. But I am running windows on a macbook using bootcamp i dont know if that is making something different.
It is installed at some other location on your computer than C:\Users\Ajay\AppData\Local\Programs\Arduino IDE. You must open the folder that contains the current installation of Arduino IDE 2.x in step (3) of my instructions:
So figure out where you have Arduino IDE installed and then try the instructions again.
PS C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit> & ".\Arduino IDE"
Arduino IDE 2.1.2-nightly-20230725
Starting backend process. PID: 2864
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Ajay/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-25T21:40:59.197Z root INFO Backend Object.initialize: 6.1 ms [Finished 1.808 s after backend start]
2023-07-25T21:40:59.197Z root INFO Backend Object.configure: 4.9 ms [Finished 1.808 s after backend start]
2023-07-25T21:40:59.198Z root INFO Backend MessagingContribution.onStart: 2.0 ms [Finished 1.808 s after backend start]
2023-07-25T21:40:59.199Z root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 1.873 s after backend start]
2023-07-25T21:40:59.200Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 1.873 s after backend start]
2023-07-25T21:40:59.201Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 1.873 s after backend start]
2023-07-25T21:40:59.202Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 64.6 ms [Finished 1.873 s after backend start]
2023-07-25T21:40:59.202Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 1.873 s after backend start]
2023-07-25T21:40:59.203Z root INFO Backend ElectronTokenBackendContribution.configure: 1.8 ms [Finished 1.875 s after backend start]
2023-07-25T21:40:59.232Z config INFO >>> Initializing CLI configuration...
2023-07-25T21:40:59.232Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 1.875 s after backend start]
2023-07-25T21:40:59.233Z root INFO Backend ConfigServiceImpl.onStart: 1.1 ms [Finished 1.876 s after backend start]
2023-07-25T21:40:59.234Z config INFO Loading CLI configuration from c:\Users\Ajay\.arduinoIDE\arduino-cli.yaml...
2023-07-25T21:40:59.235Z daemon INFO Starting daemon from C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-25T21:40:59.235Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.5 ms [Finished 1.878 s after backend start]
2023-07-25T21:40:59.235Z root INFO Backend ArduinoDaemonImpl.onStart: 1.4 ms [Finished 1.879 s after backend start]
2023-07-25T21:40:59.235Z root INFO Backend NodeFileUploadService.configure: 2.7 ms [Finished 1.879 s after backend start]
2023-07-25T21:40:59.235Z discovery-log INFO start
2023-07-25T21:40:59.236Z discovery-log INFO start new deferred
2023-07-25T21:40:59.236Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 1.880 s after backend start]
2023-07-25T21:40:59.236Z root INFO Backend BoardDiscovery.onStart: 29.5 ms [Finished 1.909 s after backend start]
2023-07-25T21:40:59.236Z root INFO Backend FileDownloadEndpoint.configure: 29.4 ms [Finished 1.909 s after backend start]
2023-07-25T21:40:59.236Z root INFO Backend AuthenticationServiceImpl.onStart: 0.7 ms [Finished 1.911 s after backend start]
2023-07-25T21:40:59.236Z root INFO Backend PluginApiContribution.configure: 0.8 ms [Finished 1.912 s after backend start]
2023-07-25T21:40:59.238Z root INFO Backend HostedPluginReader.configure: 0.6 ms [Finished 1.913 s after backend start]
2023-07-25T21:40:59.238Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.913 s after backend start]
2023-07-25T21:40:59.239Z root INFO Backend PlotterBackendContribution.configure: 1.6 ms [Finished 1.915 s after backend start]
2023-07-25T21:40:59.245Z root INFO Theia app listening on http://localhost:56967.
2023-07-25T21:40:59.253Z root INFO Finished starting backend application: 9.6 ms [Finished 1.922 s after backend start]
2023-07-25T21:40:59.265Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ajay/.arduinoIDE/plugins does not exist.
2023-07-25T21:40:59.266Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Ajay/.arduinoIDE/extensions does not exist.
2023-07-25T21:40:59.267Z root WARN The local plugin referenced by local-dir:C:\Users\Ajay\.arduinoIDE\plugins does not exist.
2023-07-25T21:40:59.307Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Ajay\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Ajay\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-25T21:40:59.308Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-25T21:40:59.312Z config INFO Loaded the CLI configuration.
2023-07-25T21:40:59.333Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Ajay/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Ajay/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-07-25T21:40:59.334Z config INFO Validating the CLI configuration...
2023-07-25T21:40:59.340Z config INFO The CLI config is valid.
2023-07-25T21:40:59.341Z config INFO <<< Initialized the CLI configuration.
2023-07-25T21:40:59.383Z root INFO Resolve plugins list: 149.5 ms [Finished 2.059 s after backend start]
2023-07-25T21:40:59.608Z daemon INFO time="2023-07-26T00:40:59+03:00" level=info msg="Using config file: c:\\Users\\Ajay\\.arduinoIDE\\arduino-cli.yaml"
time="2023-07-26T00:40:59+03:00" level=info msg="arduino-cli.exe version 0.33.1"
time="2023-07-26T00:40:59+03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56968
{"IP":"127.0.0.1","Port":"56968"}
2023-07-25T21:40:59.608Z daemon INFO Daemon is running.
2023-07-25T21:41:00.063Z daemon INFO time="2023-07-26T00:40:59+03:00" level=info msg="Checking signature" index="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2023-07-26T00:40:59+03:00" level=info msg="Loading hardware from: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages"
time="2023-07-26T00:40:59+03:00" level=info msg="Loading package arduino from: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2023-07-26T00:40:59+03:00" level=info msg="Missing signature file" index="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2023-07-26T00:40:59+03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-07-26T00:40:59+03:00" level=info msg="Missing signature file" index="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\installed.json"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.13"
time="2023-07-26T00:40:59+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-07-26T00:40:59+03:00" level=info msg="Loading tools from dir: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
time="2023-07-26T00:40:59+03:00" level=info msg="Loading package builtin from: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2023-07-26T00:40:59+03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-07-26T00:40:59+03:00" level=info msg="Loading tools from dir: C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-07-26T00:40:59+03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-07-26T00:40:59+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2023-07-26T00:40:59+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
time="2023-07-26T00:40:59+03:00" level=info msg="Loading libraries index file" index="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-25T21:41:00.390Z daemon INFO time="2023-07-26T00:41:00+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-07-26T00:41:00+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\Documents\\Arduino\\libraries" location=user
2023-07-25T21:41:00.472Z discovery-log INFO start request start watch
2023-07-25T21:41:00.473Z discovery-log INFO start requested start watch
2023-07-25T21:41:00.475Z discovery-log INFO start resolved watching
2023-07-25T21:41:00.500Z daemon INFO time="2023-07-26T00:41:00+03:00" level=info msg="starting discovery builtin:mdns-discovery process"
time="2023-07-26T00:41:00+03:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2023-07-26T00:41:00+03:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-07-26T00:41:00+03:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.33.1\" to discovery builtin:mdns-discovery"
time="2023-07-26T00:41:00+03:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-07-26T00:41:00+03:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.33.1\" to discovery builtin:serial-discovery"
2023-07-25T21:41:00.643Z daemon INFO time="2023-07-26T00:41:00+03:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-07-26T00:41:00+03:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2023-07-26T00:41:00+03:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2023-07-26T00:41:00+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-07-26T00:41:00+03:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2023-07-26T00:41:00+03:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-07-25T21:41:01.861Z root INFO Deploy plugins list: 149.5 ms [Finished 4.538 s after backend start]
2023-07-25T21:41:02.013Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 413.8 ms [Finished 2.624 s after frontend start]
2023-07-25T21:41:02.033Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-07-25T21:41:02.287Z root INFO Start frontend contributions: 817.7 ms [Finished 2.894 s after frontend start]
2023-07-25T21:41:02.290Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-25T21:41:02.306Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-25T21:41:02.307Z root INFO >>> Restoring the layout state...
2023-07-25T21:41:02.315Z root INFO <<< Nothing to restore.
2023-07-25T21:41:02.366Z root INFO Initialize the workbench layout: 48.5 ms [Finished 3.005 s after frontend start]
2023-07-25T21:41:02.400Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-25T21:41:02.644Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Waiting for backend deployment: 405.1 ms [Finished 3.288 s after frontend start]
2023-07-25T21:41:04.034Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476) starting instance
2023-07-25T21:41:04.065Z root INFO Frontend application start: 2100.4 ms [Finished 6.742 s after backend start]
2023-07-25T21:41:04.104Z root INFO Replace loading indicator with ready workbench UI (animation): 1010.8 ms [Finished 4.062 s after frontend start]
Checking for update
2023-07-25T21:41:04.108Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-25T21:41:04.149Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-07-25T21:41:04.790Z root ERROR ---- !!!SLOW!!! DURATION: search took 641.902 ms. Args: [{"type":"Updatable"}] ----
2023-07-25T21:41:05.075Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Sync of 22 plugins: 2392.3 ms [Finished 5.680 s after frontend start]
2023-07-25T21:41:05.077Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Loading plugin contributions
2023-07-25T21:41:05.079Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Load contributions of 22 plugins: 44.1 ms [Finished 5.724 s after frontend start]
2023-07-25T21:41:05.398Z root WARN A command arduino-include-library--WiFiNINA:Arduino is already registered.
2023-07-25T21:41:05.472Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-25T21:41:05.476Z root WARN a registered grammar configuration for 'cpp' language is overridden
Found version 2.1.1 (url: arduino-ide_2.1.1_Windows_64bit.exe)
2023-07-25T21:41:06.356Z root ERROR [hosted-plugin: 5476] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2023-07-25T21:41:06.360Z root ERROR [hosted-plugin: 5476] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2023-07-25T21:41:06.377Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): PluginManagerExtImpl/init()
2023-07-25T21:41:06.389Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-arduino-api@0.1.2 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.396Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(cortex-debug@1.5.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.397Z root INFO [hosted-plugin: 5476] Debugger contribution has been registered: cortex-debug
2023-07-25T21:41:06.398Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.399Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(cpp@1.52.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.400Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(json@1.46.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.401Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(json-language-features@1.46.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.403Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.405Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-cs@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.406Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-de@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.410Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-es@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.412Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-fr@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.428Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-it@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-ja@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-ko@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-pl@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-pt-BR@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-ru@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-tr@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(5476): initializing(vscode-language-pack-zh-hans@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:41:06.432Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2023-07-25T21:41:06.440Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-07-25T21:41:06.531Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Starting plugins.
2023-07-25T21:41:06.564Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-07-25T21:41:06.616Z root INFO [hosted-plugin: 5476] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-07-25T21:41:06.625Z root INFO [hosted-plugin: 5476] GDB server console created
2023-07-25T21:41:06.633Z root INFO [e9c49b30-e8af-4df3-a679-f2466f7d2098] Start of 22 plugins: 1541.3 ms [Finished 7.283 s after frontend start]
2023-07-25T21:41:56.883Z daemon INFO time="2023-07-26T00:41:56+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM3"
2023-07-25T21:41:56.886Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino NANO 33 IoT","fqbn":"arduino:samd:nano_33_iot","isHidden":false}],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x8057"],["serialNumber","8DBBD6D2503051364B2E3120FF040717"],["vid","0x2341"]],"hardwareId":"8DBBD6D2503051364B2E3120FF040717"}},"error":""}
2023-07-25T21:41:56.895Z root INFO Attached boards and available ports changed:
2023-07-25T21:41:56.895Z root INFO  - Attached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] on COM3 Serial Port (USB)
2023-07-25T21:41:56.896Z root INFO ------------------------------------------
2023-07-25T21:41:59.989Z root ERROR Error: Could not find menu with menu-path: ["menubar","1_file","0_sketch","2_examples","3_user_libs","WiFiNINA","Tools"].
    at t.unregisterSubmenu (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:8581611)
    at Object.<anonymous> (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:8372740)
    at e.dispose (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:2317212)
    at t.DisposableCollection.dispose (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:2316929)
    at file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:8375363
    at o (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:9859997)
    at file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:9860141
    at new Promise (<anonymous>)
    at e.exports.add (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:9859922)
    at C.update (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:8375333)
2023-07-25T21:42:00.035Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.038Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:00.050Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.089Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.112Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:00.119Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.143Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:00.148Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.202Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:00.277Z root INFO Starting language server: arduino:samd:nano_33_iot
2023-07-25T21:42:00.304Z root INFO [hosted-plugin: 5476] PLUGIN_HOST(5476): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-07-25T21:42:00.720Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.721Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:00.731Z daemon INFO time="2023-07-26T00:42:00+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:00+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-07-26T00:42:00+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
time="2023-07-26T00:42:00+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\Documents\\Arduino\\libraries" location=user
2023-07-25T21:42:01.753Z daemon INFO time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:01.755Z daemon INFO time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:01.759Z daemon INFO time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:01.767Z daemon INFO time="2023-07-26T00:42:01+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:18.425Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 297.7 ms [Finished 1.758 s after frontend start]
2023-07-25T21:42:18.442Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-07-25T21:42:18.688Z root INFO Start frontend contributions: 658.3 ms [Finished 2.015 s after frontend start]
2023-07-25T21:42:18.688Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-25T21:42:18.774Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-25T21:42:18.775Z root INFO >>> Restoring the layout state...
2023-07-25T21:42:18.778Z root INFO <<< Nothing to restore.
2023-07-25T21:42:18.829Z root INFO Initialize the workbench layout: 40.7 ms [Finished 2.176 s after frontend start]
2023-07-25T21:42:18.859Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-25T21:42:19.026Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Waiting for backend deployment: 379.1 ms [Finished 2.385 s after frontend start]
2023-07-25T21:42:20.266Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040) starting instance
2023-07-25T21:42:20.376Z root INFO Frontend application start: 1993.3 ms [Finished 83.044 s after backend start]
2023-07-25T21:42:20.403Z root INFO Replace loading indicator with ready workbench UI (animation): 939.1 ms [Finished 3.160 s after frontend start]
2023-07-25T21:42:20.408Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-25T21:42:20.408Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-07-25T21:42:20.425Z root INFO Executing startup tasks:
2023-07-25T21:42:20.425Z root INFO  - 'arduino-use-inherited-boards-config' , args: [{"selectedBoard":{"fqbn":"arduino:samd:nano_33_iot","name":"Arduino NANO 33 IoT","port":{"address":"COM3","addressLabel":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","properties":{"pid":"0x8057","serialNumber":"8DBBD6D2503051364B2E3120FF040717","vid":"0x2341"},"hardwareId":"8DBBD6D2503051364B2E3120FF040717"},"state":0,"selected":false},"selectedPort":{"address":"COM3","addressLabel":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","properties":{"pid":"0x8057","serialNumber":"8DBBD6D2503051364B2E3120FF040717","vid":"0x2341"},"hardwareId":"8DBBD6D2503051364B2E3120FF040717"}}]
2023-07-25T21:42:20.530Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:20.531Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:20.538Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:20.542Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:20.553Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:20.555Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:20.576Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:20.578Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:20.588Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:20.592Z daemon INFO time="2023-07-26T00:42:20+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:20.804Z fwuploader ERROR Error: Error executing C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe firmware list --format json: unexpected end of JSON input
    at ChildProcess.<anonymous> (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\exec-util.js:34:31)
    at ChildProcess.emit (node:events:513:28)
    at ChildProcess._handle.onexit (node:internal/child_process:291:12)
2023-07-25T21:42:20.805Z root ERROR Request updatableBoards failed with error: Error executing C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe firmware list --format json: unexpected end of JSON input Error: Error executing C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe firmware list --format json: unexpected end of JSON input
2023-07-25T21:42:21.228Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Sync of 22 plugins: 2161.8 ms [Finished 4.546 s after frontend start]
2023-07-25T21:42:21.230Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Loading plugin contributions
2023-07-25T21:42:21.233Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Load contributions of 22 plugins: 41.7 ms [Finished 4.588 s after frontend start]
2023-07-25T21:42:21.386Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:21.388Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:21.407Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:21.410Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:21.421Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:21.426Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:21.489Z root WARN A command arduino-include-library--WiFiNINA:Arduino is already registered.
2023-07-25T21:42:21.495Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:21.529Z root ERROR Error: Could not find menu with menu-path: ["menubar","1_file","0_sketch","2_examples","3_user_libs","WiFiNINA","Tools"].
    at e.exports._next (file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:9859783)
    at file:///C:/Users/Ajay/Downloads/arduino-ide_nightly-20230725_Windows_64bit/resources/app/lib/bundle.js:2:9860022
2023-07-25T21:42:21.542Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:21.551Z daemon INFO time="2023-07-26T00:42:21+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:21.639Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-25T21:42:21.640Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-07-25T21:42:22.040Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:22.043Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:22.044Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:22.075Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:22.086Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:22.301Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:22.308Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:22.372Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:22.372Z daemon INFO time="2023-07-26T00:42:22+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:22.761Z root ERROR [hosted-plugin: 12040] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2023-07-25T21:42:22.761Z root ERROR [hosted-plugin: 12040] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2023-07-25T21:42:22.772Z root ERROR [hosted-plugin: 12040] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2023-07-25T21:42:22.850Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): PluginManagerExtImpl/init()
2023-07-25T21:42:22.853Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(vscode-arduino-api@0.1.2 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.868Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(cortex-debug@1.5.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.876Z root INFO [hosted-plugin: 12040] Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(12040): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(cpp@1.52.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(json@1.46.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(json-language-features@1.46.1 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.878Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(vscode-language-pack-cs@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.890Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(vscode-language-pack-de@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-es@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.905Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(vscode-language-pack-fr@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-it@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-ja@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-ko@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-pl@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-pt-BR@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-ru@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-tr@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(12040): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:22.909Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): initializing(vscode-language-pack-zh-hans@1.70.0 with C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-25T21:42:23.051Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2023-07-25T21:42:23.127Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-07-25T21:42:23.304Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Starting plugins.
2023-07-25T21:42:23.327Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-07-25T21:42:23.396Z root INFO [hosted-plugin: 12040] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-07-25T21:42:23.444Z root INFO [hosted-plugin: 12040] GDB server console created
2023-07-25T21:42:23.473Z root INFO [9cd60998-f6bf-4f13-afe7-0037cd230df3] Start of 22 plugins: 2228.1 ms [Finished 6.832 s after frontend start]
2023-07-25T21:42:23.479Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:23.480Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:23.499Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.504Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:23.533Z root INFO Starting language server: arduino:samd:nano_33_iot
2023-07-25T21:42:23.568Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.596Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:23.611Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.628Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.638Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.639Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:23.641Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:23.658Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.663Z root INFO [hosted-plugin: 12040] PLUGIN_HOST(12040): PluginManagerExtImpl/loadPlugin(C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-07-25T21:42:23.877Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.877Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:23.900Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.900Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:23.941Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.942Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:23.954Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:23.955Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:23.999Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:24.000Z daemon INFO time="2023-07-26T00:42:23+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:24.015Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:24.022Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:24.154Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:24.155Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:24.159Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:24.167Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:24+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-07-26T00:42:24+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
2023-07-25T21:42:24.168Z daemon INFO time="2023-07-26T00:42:24+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\Documents\\Arduino\\libraries" location=user
2023-07-25T21:42:25.560Z daemon INFO time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:25.562Z daemon INFO time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:25.571Z daemon INFO time="2023-07-26T00:42:25+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:26.771Z daemon INFO time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:26.790Z daemon INFO time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:26+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
time="2023-07-26T00:42:26+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-07-26T00:42:26+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries" location=platform
time="2023-07-26T00:42:26+03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Ajay\\Documents\\Arduino\\libraries" location=user
2023-07-25T21:42:29.503Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:29.507Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
time="2023-07-26T00:42:29+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:29.529Z monitor-service INFO starting monitor
2023-07-25T21:42:29.538Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.33.1\"" monitor=serial-monitor
2023-07-25T21:42:29.553Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:29.556Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:29.559Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2023-07-25T21:42:29.565Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.33.1\"" monitor=serial-monitor
2023-07-25T21:42:29.579Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:29.587Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2023-07-25T21:42:29.591Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
2023-07-25T21:42:29.592Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Killing monitor process" monitor=serial-monitor
2023-07-25T21:42:29.599Z daemon INFO time="2023-07-26T00:42:29+03:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2023-07-25T21:42:29.601Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2023-07-25T21:42:29.623Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2023-07-25T21:42:29.633Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:29.635Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:29.636Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:29.639Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:29.658Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2023-07-25T21:42:29.683Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:29.685Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2023-07-25T21:42:29.687Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE baudrate 9600" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE dtr on" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE rts on" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
time="2023-07-26T00:42:29+03:00" level=info msg="sending command" command="OPEN 127.0.0.1:55417 COM3" monitor=serial-monitor
2023-07-25T21:42:29.693Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="received message" error=false event_type=open message=OK monitor=serial-monitor
2023-07-25T21:42:29.694Z daemon INFO time="2023-07-26T00:42:29+03:00" level=info msg="Port COM3 successfully opened"
2023-07-25T21:42:29.696Z monitor-service INFO Using port configuration for serial:COM3: {"settingsList":[{"settingId":"baudrate","value":"9600"},{"settingId":"bits","value":"8"},{"settingId":"dtr","value":"on"},{"settingId":"parity","value":"none"},{"settingId":"rts","value":"on"},{"settingId":"stop_bits","value":"1"}]}
2023-07-25T21:42:29.696Z monitor-service INFO started monitor to COM3 using serial
2023-07-25T21:42:29.737Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor serial:COM3.
2023-07-25T21:42:30.303Z root INFO Executing 'arduino.languageserver.notifyBuildDidComplete' with "file:///c%3A/Users/Ajay/AppData/Local/Temp/arduino/sketches/84442C19A41C8ED2A7C2934D028996E3"
2023-07-25T21:42:30.370Z monitor-service INFO stopped monitor to COM3 using serial
2023-07-25T21:42:30.374Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="sending command" command=CLOSE monitor=serial-monitor
2023-07-25T21:42:30.390Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="received message" error=false event_type=close message=OK monitor=serial-monitor
2023-07-25T21:42:30.391Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
2023-07-25T21:42:30.392Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2023-07-25T21:42:30.410Z monitor-service INFO monitor to COM3 using serial closed by server
2023-07-25T21:42:30.424Z monitor-service INFO monitor to COM3 using serial closed by client
2023-07-25T21:42:30.425Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2023-07-26T00:42:30+03:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
time="2023-07-26T00:42:30+03:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
time="2023-07-26T00:42:30+03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2023-07-25T21:42:30.439Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:30.447Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:30+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
time="2023-07-26T00:42:30+03:00" level=info msg="Performing 1200-bps touch reset on serial port COM3" phase="board reset"
2023-07-25T21:42:30.967Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="Waiting for upload port..." phase="board reset"
2023-07-25T21:42:30.975Z daemon INFO time="2023-07-26T00:42:30+03:00" level=info msg="from discovery builtin:serial-discovery received message type: remove, port: COM3"
2023-07-25T21:42:30.977Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"","protocol":"serial","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-25T21:42:31.103Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:31.105Z root INFO  - Detached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] from COM3 Serial Port (USB)
2023-07-25T21:42:31.107Z root INFO ------------------------------------------
2023-07-25T21:42:31.118Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:31.118Z root INFO  - Detached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] from COM3 Serial Port (USB)
2023-07-25T21:42:31.120Z root INFO ------------------------------------------
2023-07-25T21:42:31.178Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:31.184Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:31.200Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.208Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.215Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.220Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.221Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.225Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.239Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:31.245Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.246Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:31.246Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:31.278Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.287Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:31.292Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.298Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:31.313Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.316Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.317Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:31.659Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.663Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.729Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.735Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.806Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.809Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.815Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.824Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.825Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.826Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:31.828Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:31.838Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:31.851Z daemon INFO time="2023-07-26T00:42:31+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:32.046Z daemon INFO time="2023-07-26T00:42:32+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM13"
2023-07-25T21:42:32.052Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino NANO 33 IoT","fqbn":"arduino:samd:nano_33_iot","isHidden":false}],"port":{"address":"COM13","label":"COM13","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0057"],["serialNumber",""],["vid","0x2341"]],"hardwareId":""}},"error":""}
2023-07-25T21:42:32.062Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:32.066Z root INFO  - Attached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] on COM13 Serial Port (USB)
2023-07-25T21:42:32.077Z root INFO ------------------------------------------
2023-07-25T21:42:32.094Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:32.097Z root INFO  - Attached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] on COM13 Serial Port (USB)
2023-07-25T21:42:32.104Z root INFO ------------------------------------------
2023-07-25T21:42:33.025Z daemon INFO time="2023-07-26T00:42:33+03:00" level=info msg="Upload port found on COM13" phase="board reset"
2023-07-25T21:42:35.376Z monitor-service INFO starting monitor
2023-07-25T21:42:35.386Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:35.387Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
2023-07-25T21:42:35.389Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
time="2023-07-26T00:42:35+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:35.391Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2023-07-25T21:42:35.391Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.33.1\"" monitor=serial-monitor
2023-07-25T21:42:35.413Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:35.416Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2023-07-25T21:42:35.422Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2023-07-25T21:42:35.436Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2023-07-25T21:42:35.456Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:35.456Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:35.457Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:35.460Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
2023-07-25T21:42:35.485Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:35.486Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE baudrate 9600" monitor=serial-monitor
2023-07-25T21:42:35.490Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE dtr on" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE rts on" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="sending command" command="OPEN 127.0.0.1:55423 COM3" monitor=serial-monitor
time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=true event_type=open message="Serial port not found" monitor=serial-monitor
2023-07-25T21:42:35.508Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port not found
    at callErrorFromStatus (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:19)
    at Object.onReceiveStatus (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:410:73)
    at Object.onReceiveStatus (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:323:181)
    at C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\resolving-call.js:94:78
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at ServiceClientImpl.makeBidiStreamRequest (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:394:34)
 at ServiceClientImpl.monitor (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\make-client.js:105:19)
    at MonitorService.createDuplex (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:183:34)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:256:37
    at async retry (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\core\lib\common\promise-util.js:74:20)
    at async MonitorService.start (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-service.js:147:13)
    at async MonitorManager.notifyUploadFinished (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\monitor-manager.js:169:17)
    at async C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\arduino-ide-extension\lib\node\core-service-impl.js:142:13
    at async JsonRpcProxyFactory.onRequest (C:\Users\Ajay\Downloads\arduino-ide_nightly-20230725_Windows_64bit\resources\app\node_modules\@theia\core\lib\common\messaging\proxy-factory.js:132:24)
2023-07-25T21:42:35.521Z monitor-service INFO monitor to COM3 using serial closed by server
2023-07-25T21:42:35.523Z monitor-service INFO monitor to COM3 using serial closed by client
2023-07-25T21:42:35.524Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
2023-07-25T21:42:35.668Z daemon INFO time="2023-07-26T00:42:35+03:00" level=info msg="from discovery builtin:serial-discovery received message type: remove, port: COM13"
2023-07-25T21:42:35.670Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"COM13","label":"","protocol":"serial","protocolLabel":"","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-25T21:42:35.679Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:35.689Z root INFO  - Detached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] from COM13 Serial Port (USB)
2023-07-25T21:42:35.695Z root INFO ------------------------------------------
2023-07-25T21:42:35.706Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:35.709Z root INFO  - Detached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] from COM13 Serial Port (USB)
2023-07-25T21:42:35.709Z root INFO ------------------------------------------
2023-07-25T21:42:37.498Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2023-07-25T21:42:37.516Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:37.517Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:37+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:37.518Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:37.522Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.33.1\"" monitor=serial-monitor
2023-07-25T21:42:37.541Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:37.541Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE baudrate 9600" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
2023-07-25T21:42:37.542Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE dtr on" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE rts on" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command="OPEN 127.0.0.1:55424 COM3" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="received message" error=true event_type=open message="Serial port not found" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="sending command" command=QUIT monitor=serial-monitor
2023-07-25T21:42:37.544Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="received message" error=false event_type=quit message=OK monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=info msg="Killing monitor process" monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=error msg="Sent kill signal" error="TerminateProcess: Access is denied." monitor=serial-monitor
time="2023-07-26T00:42:37+03:00" level=error msg="stopped decode loop: EOF" monitor=serial-monitor
2023-07-25T21:42:37.555Z daemon INFO time="2023-07-26T00:42:37+03:00" level=info msg="Monitor process killed" monitor=serial-monitor
2023-07-25T21:42:37.572Z monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: command 'open' failed: Serial port not found
for call at
    at runNextTicks (node:internal/process/task_queues:60:5)
    at process.processTimers (node:internal/timers:504:9)
2023-07-25T21:42:37.574Z monitor-service INFO monitor to COM3 using serial closed by server
2023-07-25T21:42:37.574Z monitor-service INFO monitor to COM3 using serial closed by client
2023-07-25T21:42:38.776Z daemon INFO time="2023-07-26T00:42:38+03:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM3"
2023-07-25T21:42:38.777Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino NANO 33 IoT","fqbn":"arduino:samd:nano_33_iot","isHidden":false}],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x8057"],["serialNumber","8DBBD6D2503051364B2E3120FF040717"],["vid","0x2341"]],"hardwareId":"8DBBD6D2503051364B2E3120FF040717"}},"error":""}
2023-07-25T21:42:38.785Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:38.788Z root INFO  - Attached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] on COM3 Serial Port (USB)
2023-07-25T21:42:38.790Z root INFO ------------------------------------------
2023-07-25T21:42:38.792Z root INFO Attached boards and available ports changed:
2023-07-25T21:42:38.792Z root INFO  - Attached board: Arduino NANO 33 IoT [arduino:samd:nano_33_iot] on COM3 Serial Port (USB)
2023-07-25T21:42:38.793Z root INFO ------------------------------------------
2023-07-25T21:42:38.996Z daemon INFO time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:39.000Z daemon INFO time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:38+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:39.005Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.011Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:bossac@1.7.0-arduino3"
time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:39.045Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.045Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:39.116Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.123Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2023-07-25T21:42:39.135Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.136Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:39.157Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.159Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:39.161Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:39.163Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.186Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:39.241Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.255Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:39.304Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.311Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS-Atmel@1.2.0"
2023-07-25T21:42:39.370Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.372Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:openocd@0.10.0-arduino7"
2023-07-25T21:42:39.378Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.392Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arduinoOTA@1.2.1"
2023-07-25T21:42:39.587Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:CMSIS@4.5.0"
2023-07-25T21:42:39.587Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Required tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-07-26T00:42:39+03:00" level=info msg="Starting monitor process" monitor=serial-monitor
2023-07-25T21:42:39.592Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Monitor process started successfully!" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="HELLO 1 \"arduino-cli 0.33.1\"" monitor=serial-monitor
2023-07-25T21:42:39.609Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="received message" error=false event_type=hello message=OK monitor=serial-monitor
2023-07-25T21:42:39.609Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command=DESCRIBE monitor=serial-monitor
2023-07-25T21:42:39.610Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="received message" error=false event_type=describe message=OK monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE baudrate 9600" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="received message" error=false event_type=configure message=OK monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE bits 8" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE dtr on" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE parity none" monitor=serial-monitor
2023-07-25T21:42:39.611Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE rts on" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="CONFIGURE stop_bits 1" monitor=serial-monitor
time="2023-07-26T00:42:39+03:00" level=info msg="sending command" command="OPEN 127.0.0.1:55425 COM3" monitor=serial-monitor
2023-07-25T21:42:39.622Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="received message" error=false event_type=open message=OK monitor=serial-monitor
2023-07-25T21:42:39.637Z monitor-service INFO Using port configuration for serial:COM3: {"settingsList":[{"settingId":"baudrate","value":"9600"},{"settingId":"bits","value":"8"},{"settingId":"dtr","value":"on"},{"settingId":"parity","value":"none"},{"settingId":"rts","value":"on"},{"settingId":"stop_bits","value":"1"}]}
2023-07-25T21:42:39.638Z monitor-service INFO started monitor to COM3 using serial
2023-07-25T21:42:39.639Z daemon INFO time="2023-07-26T00:42:39+03:00" level=info msg="Port COM3 successfully opened"
2023-07-25T21:42:39.643Z monitor-service INFO No port configuration changes have been detected. No need to send configure commands to the running monitor serial:COM3.
[6308:0726/004257.425:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
@ptillisch I posted the code in two parts as it is too long for a single reply. Please let me know if this is what you needed or I’ll retry. Also thank you so much for helping me out.
