Hello,
I have a very simple code as follows:
void loop(){
Serial.println("test2--");
It is only for simplifying the problem scenario.
The thing is that I can perfectly upload that code to Arduino using the Arduino IDE running on the Raspberry with GUI.
The problem is that when I try to upload the code to Arduino nano using the terminal commands over ssh it is unable to upload the code.
I've noticed that the command for uploading the code to Arduino differs between the IDE and the Terminal.
The command run in the IDE is:
/opt/arduino-1.8.9/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/arduino_build_825460/testMenu.ino.hex:i
and the output is as follows:
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/opt/arduino-1.8.9/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/pi/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_825460/testMenu.ino.hex"
avrdude: writing flash (1486 bytes):
Writing | ################################################## | 100% 0.27s
avrdude: 1486 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_825460/testMenu.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_825460/testMenu.ino.hex:
avrdude: input file /tmp/arduino_build_825460/testMenu.ino.hex contains 1486 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.22s
avrdude: verifying ...
avrdude: 1486 bytes of flash verified
avrdude done. Thank you.
However, in the Terminal the result is the following:
make do_upload
make[1]: se entra en el directorio '/home/pi/ASTB_stress_test_V3/testMenu'
/usr/share/arduino/hardware/tools/avr/../avrdude -q -V -p atmega328p -C /usr/share/arduino/hardware/tools/avr/../avrdude.conf -D -c arduino -b 57600 -P /dev/ttyUSB0 \
-U flash:w:build-nano328/testMenu.hex:i
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
make[1]: *** [/usr/share/arduino/Arduino.mk:1462: do_upload] Error 1
make[1]: se sale del directorio '/home/pi/ASTB_stress_test_V3/testMenu'
make: *** [/usr/share/arduino/Arduino.mk:1455: upload] Error 2
First I tought it could be due to a Serial interface chip drivers, but I can connect to the Serial port on the RPi and read the Serial.println message perfectly. Also, I can do it over the Arduino IDE. So it seems something with the command parameters and maybe the data speed when programming over the port.
Any ideas what is the difference between IDE and Terminal and how to make the code upload work over Terminal?
I've also tried with other arduino clones and it seems to work well the terminal upload on those boards.
