Alright, so I'm working on interfacing my Arduino to a NES controller. I found this very handy program at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1254964306
and I understand almost all of it, theres just one line that confuses me:
The second line makes sense, as you're going to get a resultant byte from all of the individual bytes that each consist of 7 0s and a single 1. But what is the first line doing, and why is it doing it?
The first line: << is a shift right left*. it moves all bits in controllerdata one place to the right left
The second line: adds the outcome of digitalRead() which is a 0 or a 1 (used as a single bit) to controller_data
so after 8 times a byte is filled with 8 readings of digitalRead().
Not to be picky, but its a shift left. What it means is that your program is reading the digital input, and setting each incoming value to a bit of the byte. The first bit received will go to the MSB and the last will go to the LSB and so on.
For example, the byte in that program starts as 0.
Controller data = 00000000
Say it receives a one, it is written to the LSB to result in Controller data = 00000001
This is then shifted left for: Controller data = 00000010
Say it recieves another 1,it is also written to the LSB to result in Controller data = 00000011
This is then shifted left for: Controller data = 00000110
That was the first tutorial I did and it's the only one that people still care about. Long live Nintendo. It took me hours to cobble that stuff together.
